Weird Rear Defroster Problem
Red97LT1
11-08-2004, 11:50 AM
Now since it's getting cold and frost is starting to get onto the back glass,I have noticed that the defroster light will go out after about 15-20 secs. Now if it is warm and nothing is on the glass,it works fine???? :confused:
ehsfootball71
11-08-2004, 01:59 PM
try putting a 30A fuse in place of the 30A breaker
Red97LT1
11-08-2004, 06:23 PM
Ok. I replaced the 30a breaker with a 30a fuse and it still cutoff,just not as soon.But,the breaker was reallyHOTTTTTTT when i removed it. :cry: I could feel the heat on the back window when it was on though.
Red97LT1
11-08-2004, 07:05 PM
Well,
I got my manual and it told me how to check the grid.Anything below 6 volts was ok and anything around 10 volts means a broken grid. I did it and it found a break in the bottom grid about 1/4 inch long. It's amazing how something that small causes big problems. The short was causing the breaker to get hot and shut off i guess. :D
Red97LT1
11-10-2004, 07:35 PM
Fixed the grid all the volts check out,but the breaker still gets hot.could it be because the windoe doen't have nay frost on it right now?
shoebox
11-10-2004, 08:23 PM
The breaker is always going to get some heat in it. Are you saying it still cuts off quickly?
Red97LT1
11-10-2004, 08:28 PM
no.Before it would cutoff after about 30 secs.Now it's more like 2-3mins.That's why i thought that it may be cutting off because there is no frost.
shoebox
11-10-2004, 08:30 PM
I would retest it on a frosty day. :)
Red97LT1
11-10-2004, 08:50 PM
I hear ya. ;)
