RichyZ28
11-08-2004, 11:01 AM
hey guys.
my friend has a 3.73 rear end hes gonna sell me, its a 3 channel abs rear end. came off a 96 formula and i have a 97 z28 will that bolt right up? someone said that it wont fit if i have traction control but i dont. someone said i had a 4 channel abs but i thought i had 3channel....got any info on this?
Capn Pete
11-08-2004, 11:44 AM
Yes, it should bolt right up. 3-channel is for non-traction control cars, 4-channel is with traction control:cool:.
OutsiderIROC-Z
11-08-2004, 12:47 PM
So a rear differential out of a traction controlled car won't go directly into a non-traction controlled car, and vice versa?
RichyZ28
11-08-2004, 03:33 PM
thats what i thought ijust wanted to be 100% sure, thanks pete
Capn Pete
11-08-2004, 04:34 PM
No prob:cool:.
Bill, the difference between an ABS only (3-channel) vs. a traction control car (4-channel) is that the reluctor ring is built onto the carrier of the 3-channel diff, whereas there is a reluctor ring on the end of each axle for a 4-channel setup. The conversion can be made, but it's a bit of work. Just find the one specific to what you need.....it's easier;).
OutsiderIROC-Z
11-08-2004, 07:07 PM
Thanks for the info Pete. I have a buddy of mine who has a 94 Formula with a 3.73 rear in it and my 95 Z28 has what I believe is a 3.23 gear and he is willing to swap me straight across, but if I am going to go to the trouble of going into a rear differential, I am going to buy new gears and put them in my housing.
Thanks again for your information. It is much appreciated. :D
No prob:cool:.
Zepher
11-09-2004, 04:13 PM
A 3 Channel ABS rear will work for either car. If you have TCS, you just need to put TCS axles and backing plates on the 3 channel rear and just plug the sensor hole on top of the pumpkin if it's missing.
OutsiderIROC-Z
11-10-2004, 09:26 AM
Thanks again for the info. If I have to open up the differential for other than changing the fluid, I am going to put new gears in mine.
