Mr Kevlar
11-07-2004, 11:38 PM
What size are the factory wheel studs on a 97 T/A ??
I heard they were the 12mm x 1.5, 2.5 length and just needed to verify.
What Size Wheel Studs?Mr Kevlar 11-07-2004, 11:38 PM What size are the factory wheel studs on a 97 T/A ?? I heard they were the 12mm x 1.5, 2.5 length and just needed to verify. Injuneer 11-07-2004, 11:57 PM I just measured a stock stud, and the overall length, including the head, the knurl, the threaded portion and the unthreaded end is about 2-1/8". It is 12mm - 1.5. The stud projects from the hub about 1.6". I had to buy 2.67" studs to run Weld Pro-Stars (the "center" is 1" thick) with a 5/16" spacer. | ||
