FS: 1997 Camaro Z/28 Six Speed / Hardtop, 100k
Hyperspeed97z28
11-06-2004, 10:20 PM
I am selling my 1997 Z/28 Six Speed
It has just fewer than 100k miles on the clock
-Cayenne Red Metallic Paint (Which is in Excellent Condition)
-Extremely Clean Inside with Leather Interior (cloth door panels) and Power Drivers Seat
-It's a Hardtop Coupe
-Chrome 2002 SS 10 Spoke Rims with EXCELLENT Tires all around (Hankook Ventus K-104's 275/40/17’s: Front's 75%, Rear's 95%)
-CLEAN Car-Fax
-Sub Frame Connectors
-32 mm Front Sway Bar "1LE" with New Poly End links/Bushings
-24 mm Rear Sway Bar "3'rd Gen" with Newer Poly End links/Bushings
-4.10 Rear End (PCM Programmed for them)
-1LE Shocks and springs with not even 10k miles on them (Not the KONI's, these are the 1LE spec DeCarbons)
-SLP Bump Stop Extensions in the rear
-Reflective 3D Rear "Camaro" Insert Decals (Reflect a shade similar to the color of the car but a few shades brighter, VERY NICE TOUCH)
-Tinted Hatch Window, and Front Tint Strip both are 5%
-Tinted Driver/Passenger side windows @ 20%, (will remove for buyer)
- 3D Domed Decals for the Sail Panels and Door Handles and front bumper emblem, Very Classy looking Clean touch !
- 30th Logo's for above the side fender Z/28 logos, also a nice touch!
-Billet Grill which adds to the CLEAN look
-Front and Rear Clear Turn-signals
-Ram Air Scoop under front bumper for Cold Air Intake
-SLP Cold Air Intake - BLACK in color
-SLP Strut Tower Brace, BLACK in color
-MTI Pan-hard Rod, BLACK in color
-MSD 6A Ignition box with adapter for the 96/97 cars, no cutting into the harness
-SLP Headers, 93 Style, No EGR, NO AIR PUMP, HOLLOW CAT (All Removed fully and CLEAN, done the right way, PCM PROGRAMMED ALL CODES OUT, NO ENGINE LIGHTS )
- Hooker Cat back with a Cut-out welded in just before the "over the axle" pipe
- Polished Alum Radiator Cover, Polished Valve Breather, Polished Battery Cover, Polished Throttle Cover, Polished Master Cylinder Cover, and a Polished Fuse box Cover
-Mad wolf tuned PCM
-MSD PLUG WIRES and NGK TR-55 PLUG'S "25k miles on them"
-15k mile old AFS-75 O2 Sensors "AC Delco’s"
-1LE Air intake elbow
-3 1/2 inch ALUM Driveshaft -RK-Sport/Spicer-
-30k Mile old Opti-Spark and Water pump and the gaskets changed (AC DELCO PARTS)
-SLP Clutch Disk and Pressure Plate with 15k miles on the setup, Stock resurfaced flywheel, did rear main seal at the same time
-Mobil 1 used since I owned it at 39k miles, switched to Maxlife 10w-30 at 75k miles with K@N Oil-Filters (hp-3002)
-Tranny Fluid and Rear end fluid both changed TODAY, Max life dex 3 in the tranny and, gm 80w-90 with gm additive in the rear end, with fel-pro gasket
-New pcv valve and fuel filter done TODAY
-White faced Speedo gauges, White faced headlight layover and white faced layover for the a/c panel
-PRO 5.0 Shifter with White Hurst Classic Shift Knob
-Poly Tranny Mount and T/A mount
-Solid Motor Mounts
-Rag joint elim done
-air foil for TB
-Intake leak fixed before clutch install 15k miles ago (fel-pro gaskts)
There may be more I can't think of at the moment... I'll add it if there is more...
This is a really really really CLEAN car, I can't stress that enough!! I have fully maintained this car myself with quality parts, The car runs 100% the rear end does have a bit of gear whine, it doesn’t bother me but it could be made silent again if it was took to a gear shop, I will include a Brand New set of MSD Plug Wires and AC DELCO PLUGS for the new owner, I also have a bunch of other parts for the buyer if interested (Stock Sway bars, extra stock rear LCA's, etc..)
The A/C blows VERY VERY COLD, Recently recharged over the summer, The only reason I am selling is because I want a full size Tahoe and I will be moving out in 2 months, I need an all around car/truck with the summer/winters here, I hate to see it go but I don’t really have the time for it anymore, It deserves another owner who will keep it in the shape it's in now..
I am asking $8500 or BEST REASONABLE OFFER for this car, The Kelly Blue Book Suggested Retail is $8,395 for it in excellent shape, which this car is certainly in, Then Figure in all the extra's I have with receipts and service records, etc and this car is well worth what I'm asking and probably a little more to the right person...
Pictures are in my sig below, just click on it, it’s a link to web shots where I have many photos, if you need/want a photo of another spot on the car, just ask and I will take some for you
Thanks Everyone!!! :)
Hyperspeed97z28
11-06-2004, 11:02 PM
It's now on E-BAY !!!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4502265617
Hyperspeed97z28
11-08-2004, 08:04 AM
To the TOP ...
MUST SELL THIS CAR !!!
Moving in Jan and have no place for this !!!
Hyperspeed97z28
11-09-2004, 07:53 AM
To the TOP ...
TTT ...
Hyperspeed97z28
11-10-2004, 07:53 AM
Ttt
Hyperspeed97z28
11-11-2004, 07:00 AM
NEW PICS ADDED YESTERDAY !!!
http://community.webshots.com/user/hyperspeed97z28
Hyperspeed97z28
11-12-2004, 07:48 AM
ttt
Donohue96M6Z28
11-12-2004, 11:37 PM
where u movin to? u want to part any of it out?
Hyperspeed97z28
11-13-2004, 08:20 AM
I'm moving not far from home, but I also dont have much time for the car anymore with my job and all so I wanna see it go to someone who can enjoy it as I did, I wont part out a car thats 100% in working order ......
Hyperspeed97z28
11-14-2004, 11:39 AM
Lower Reserve @ $7800 !!!
MUST SELL !!! NEEDS NEW REAR END, EASY $300 FIX AND SWAP !!!!
MUST SELL !!!!!!!
110% CLEAN CAR !!!!!!!
YOU REALLY WONT FIND MANY LIKE THIS !!
Hyperspeed97z28
11-16-2004, 08:16 AM
$7500 TAKES IT HOME !!!!!
MUST SELL
CANT GO LOWER THEN $7500 !!!!!
KBB VALUE IS $8,395 and believe me this car is in EXCELLENT SHAPE !!!
The ONLY thing it needs is a rear end or a t-56 (at service shop today to figure out which of the 2 it needs)
Hyperspeed97z28
11-17-2004, 06:16 AM
Didnt sell on ebay :(
Anyways...
Found out it only needs a new ring n pinion...
I am taking a road trip sunday and replacing my whole rear with a stock 10 bolt 3.42's ...
Would still like to sell this car !!
$7500 FIRM !!!
Keep in mind over 5k in extra's ....
Hyperspeed97z28
11-19-2004, 08:13 AM
$7500 FIRM takes it !!
Blue Book is $8300 !!!
rjwz28
04-26-2008, 09:45 AM
I know its been four years but i'm dying to know if that camaro ever ended up selling. I've been madly searching for a 97 hardtop and found this on google and now its gonna bug me if I don't find out whatever happened to this car.
FiefSS
04-26-2008, 05:45 PM
Yes it did sell, the guy selling the car hasn't posted in a long time though.
http://camaroz28.com/forums/showthread.php?p=4528227#post4528227
Theres a post with the car and new wheels.
rjwz28
04-29-2008, 09:08 AM
Wow, looks pretty sweet. Thanks a lot!
