WTB: Over the winter block, leather, 12-bolt
Old Nov 6, 2004 | 07:50 PM
NoFear95's Avatar
LT1 or LT4 block - Good Condition (rebuildable). Looking for no bigger than 383 for a FI application.
-Full Leather Interior for a Trans-Am (front/rear seats + door panels) Graphite color. Excellent condition.
-12 bolt rearend, 3:73 gearing, ABS Strange pref. 4th gen.
Old Nov 7, 2004 | 11:02 AM
XxXTransAmXxX's Avatar
Re: WTB: Over the winter block, leather, 12-bolt
Hey bro I have a LT1 Block that's good to go! It's already been:
Heat Tanked 2 times (once over night)
Bored .030"+
Cam Bearings installed
Freeze Plugs installed
Painted black
Perfect for a 355, or you could clearance for the 383 crank...Plus I'm in IL!!!! (Georgetown, IL around the Champaign area) Asking $500, since I have a lil over $300 in machining, but will negotiate the $$ since your closer, and can pick it up! Email me @ XxXTransAm2@aol.com or IM me on AIM @ MxRacer476 I have pics...
Old Nov 7, 2004 | 01:31 PM
blk97ta's Avatar
maybe i can help !here's the situation i have a moded 97 ta which i'm looking to partially part out if the money is right ! the reason is my friend has a 91 syclone for sale (i already have a moded typhoon ) but money is tight right now so i'm looking to sell the big dollar items first item is :
moser 12 bolt (30 spline axles, 1/2 inch racing studs, eaton rebuildable posi,4.10 richmond gears,heavy duty rear cover,1350 yoke )set up by moser ! $1800 plus shipping . it has maybe 1500 miles on it i bought it 8/25/03
complete t-56 tranny ,bellhousing, pedals,clutch slave cylinder ,flywheel ,spec stage 3 clutch , hurst shifter ,crossmember ,center console and rubber boot . the tranny was rebuilt by a professional 5000 miles ago ! $2000 plus shipping
next up is a set of lt-4 heads, 7/16 studs, comp cams 1.6 rr non self aligning, comp cams guide plates, lt-4 intake, comp cams 306 cam, comp cams roller lifters,lucas 38# injectors $2500 this stuff has 1500 miles on it also ! it made 376.8 rwhp and 340rwtq all motor ! i have reciepts for all of this stuff !
this is still in my car (all of it ) if there is enough interest i will pull my car apart it ran a 12.16 at 116 with a set of 5 year old drag radials ! with a stock bottom end ! i was running nitrous to get that but it shows this set up with tires would be a mid 11 car ! if interested call me @ 203 213 9976 KEVIN or email me blk97ta@comcast.net
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
