95TA8280
11-06-2004, 12:20 PM
OK so my turn signals stopped working after they were fussy for awhile. But my hazards work. I checked the fuse and it isn't blown. DO the hazards and turn signals have the same bulb? WHat else could it be, if they do?
Car is the LS1 in the sig.
thomas_quinn
11-06-2004, 01:38 PM
Might be the multifunction swith.
4U 2 NV
11-06-2004, 07:23 PM
are they dual element bulbs? if so one being out can make all stop working on the particular side.
94ZRiCeKiLr
11-06-2004, 07:52 PM
if i remember correctly, there are two bulbs in there. 1 is for the turn signal and the other is the flashers AND daytime running lights.
Nick_dub
11-07-2004, 12:40 AM
There are two separate flashers. One for the turn signals and one for the hazards. The turn signal one is next to your right knee when sitting in the driver's seat (under the dash, front of console). I think you have a flasher that is bad. :eek:
1quick1
11-07-2004, 03:13 AM
I don't know for a fact on LS1's but on some other cars if you have a brake light out it would affect your turn signals.
95TA8280
11-07-2004, 11:07 PM
But what are the odds that BOTH bulbs would blow at the same time?
SMUJeremy
11-08-2004, 04:40 PM
Check this, they sell them at Autozone for under $10 I believe.
convertz
11-09-2004, 12:29 PM
I would put money on the flasher being bad also, especially since u said they were being fussy before. I had the same problem, sometimes they work sometimes they get stuck on, sometimes nothing.
