Bose Radio
Ponykillr
11-06-2004, 09:50 AM
I am buying a 1993 Camaro. I have an extra Bose radio from my current 95 Z28. What do I need to do to put the bose in the 93? Do i need to pull out all the wiring from the 95? Any help in this area will be great. I have no idea about how to work with radios. I hope for a direct switch if possible.
LukeZ28
11-11-2004, 11:03 PM
If the 93 doen't have a bose system, then it probably wouldnt be worth converting everything over to bose which would include bose speakers and sub. Bose isnt compatable with other manufactures.
madwolf
11-12-2004, 10:21 PM
Bose was available in 93s and other than yellow coloring on the radio, it was pretty much the same thing as a 94 Bose system.
The major difference between a 93-94 system and a 95 system is that 95s got a 5 speaker system and 93-94s only had 3. The 95 headunit will work in a 93 though, provided it is already bose equipped. (even if it has a cassette bose deck right now)
If you want to convert to the 5 speaker system, you will need a 95 sub box, its wiring harness and the rear 2 speakers.
Here (http://www.soltan.net/pix/bose1.jpg)'s a picture of the 93 bose deck.
