much of a difference?
Old Nov 3, 2004 | 07:10 PM
DiabloGT's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...497313187&rd=1
would i notice much of a difference from this one and the stock rear end?
Old Nov 3, 2004 | 07:53 PM
Kataklysm's Avatar
Re: much of a difference?
What are you looking to gain? That rear end gives no details, it could be a 9 bolt a 10 bolt or something else. If you are looking for different gearing just go buy some new gears. What rear do you have now? More info would help.
Old Nov 3, 2004 | 08:08 PM
GoFast908Z's Avatar
Member
what gears do you have now? If you have an auto, 4:10s would probably be too much for the street. If you have a manual, it is a good choice of gears. However it will KILL your top end mph. You should also be warry of buying something like that off of ebay.
Old Nov 3, 2004 | 08:10 PM
DiabloGT's Avatar
i have a 95 z28 auto and i was thinking of something like on the rear end to help some more power on it
Old Nov 3, 2004 | 08:12 PM
GoFast908Z's Avatar
Member
just do a gear swap up to 3.73. You don't need a whole new rear end. just do gears and some sticky tires to help with the traction ( you'll need it ). Maybe some lower control arms to help plant the rear end too.
Old Nov 3, 2004 | 08:26 PM
RedHottG2's Avatar
What kind of HP do you have right now ? are you stock, or do you have 400 RWHP ? If you are moddified with lots of power then a 12 bolt would be a good choice with lower gears. If you are fairly stock, just get some 3.73s and sticky tires and call it a day.
Old Nov 3, 2004 | 08:50 PM
DiabloGT's Avatar
its stock... planning on getting 17" x 9.5" in front anf 18"x 10.5" in back which tires will last a good while?
Old Nov 3, 2004 | 09:10 PM
RedHottG2's Avatar
Well if your looking for something that lasts a pretty good while, stay away from nitto's or BFG drag's. I would suggest a set of Kumo's or really any decent Z rated tire. The Z will wear a little more then others but it will still give you good grip at the same time and give you a good bit of tire life.
Old Nov 4, 2004 | 02:47 PM
WestCoast96Z28's Avatar
I say beware. Don't know the seller, but he/she is new..no feedback...just joined EBay. It's a pricey item, and there's no picture either. See where I'm heading....
As for your car...if you're basically stock, just do the gear swap. Do you know what gears you have now that came with the 95 A4? I have a 96 A4 and which has a series 2 carrier. You'll should check that out before picking your gears...if you have series 2 or series 3.
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
