Idiot lights on dash PLEASE HELP
Old Nov 3, 2004 | 12:00 PM
95z6spd's Avatar
Hey guys. i recently got done wiring up an Accell 375+ on my 95 Camaro Z28. I think i need to rewire the switched ignition source. I cut=rrently have it hooked up to one of the switched sources in the fuse box under the hood(fans) I used a jumper on the fuse. Where should I hook up this wire to? A mechanic told me to use te pink wire that is under the dash from the ignition on the steering column. Right now I have an ASR light, ABS INOP light, Air Bag light on the dash along with the fog lights not working. I think I blew a fuse/relay. I checked all the fuses tho and they all lokked good. DOes anyone know which relay it would be that all of those are based on. And also if that pink wire is the one to hook it up to. Any and all help is greatly appreciated.
Thanks in advance
Adam
Old Nov 3, 2004 | 04:19 PM
kmook's Avatar
Advanced Tech Moderator
Re: Idiot lights on dash PLEASE HELP
This should be discussed in General Fbody Tech, transfering.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Alien
Jun 27, 2015 01:13 PM
Brake_L8
Jan 20, 2015 09:44 AM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
