2ktransam
10-31-2004, 10:18 PM
Here is my dyno run on 5.5 lb and everything that is in my sig. The lower pull is my h/c package pull on the same dyno before I installed the turbo. I have a NA cam right now so my numbers could have been a good bit better. You can view my dyno sheet at
http://my.starstream.net/f8lpony/Photos/Cars/Kris%205.5psi%20sm.bmp
MEAN LT1
10-31-2004, 10:46 PM
Nice numbers man, a little shakey up top though ehh?.
2ktransam
10-31-2004, 10:52 PM
Yeah, My fuel pump was struggleing as soon as it hit boost.
sherwinZ28
11-01-2004, 04:20 PM
So you're saying you threw on the STS turbo system on your 112LSA cam?
I have a 230/236 heads/cam on my car right now but didn't want to throw on the STS sytem due to people telling me it won't work properly with that cam. I believe my cam is also 112 LSA. I had a good deal on the package as well but skipped it.
What is a good cam for the STS setup? I've been thinking about switching over to that since it's easily smogged in Cali(not that I can pass smog right now).
5.0THIS
11-01-2004, 06:54 PM
When you planning on getting some track times with it? Post up when you do. Nice dyno numbers.
96TurboTA
11-01-2004, 07:02 PM
Not bad. Is that the base STS kit? I see spool/max torque is around 3800rpm.
F8L Z71
11-01-2004, 08:29 PM
On the LS1 motors, especially a 5.7L the 226dur cams seem to be somewhat popular.
I'm running a 226/220 .591/.554 116 cam in my 5.3L truck.
I think some of the bigger cube guys are using 336/332 high lift cams.
5.0THIS
11-02-2004, 01:07 AM
:eek: Did you mean 236/232? If not I've never seen such a cam. :eek:
F8L Z71
11-02-2004, 10:21 AM
DOH! Total typo! LOL
2ktransam
11-10-2004, 12:39 AM
Yeah I threw the STS kit on with the 112 lsa cam. It works really well but I think a good turbo cam would help it out. Don't let people tell you that the kit won't work with your cam, it just won't be at the top of its potential. I have a big turbo cam that I am going to put into it but I blew a head gasket so it will be a while before I have any new numbers for everybody.
2ktransam
11-10-2004, 12:40 AM
All of the tracks are closed around here and I blew a head gasket so I am hoping to put up some good number in the spring.
2ktransam
11-10-2004, 12:52 AM
This is the upgraded kit with the gt67 turbo. I did the upgrade to get more power up top with my head and cam package. This kit really spools quicker on the street than on the dyno and the lag is not really noticable on the street.
sherwinZ28
11-10-2004, 05:24 PM
Great, thanks for the information :bow: !
SMOKNZ
11-10-2004, 05:27 PM
= your running lean, better do something about it!!
bunker
05-22-2005, 02:20 AM
Hey SMOKNZ, just looked at your dyno graph, seems there is something wrong your torque/HP crosses at 4500 rpm, it should be 5250 or so.
