oneqwkfbody
10-30-2004, 07:40 PM
anyone know who sells them or where i can get some...anyone here make some?
please lemme know...i already tried baer and they of course dont part out the sets... i have access to 95 rotr and calipers from a vette
thanks
brian
oneqwkfbody@yahoo.com
Z28barnett
10-31-2004, 11:03 AM
GM used to make them for racing brakes. You would have to cut the ears off of the spindle and mount the bracket.
The following info is from GM parts direct, but they are GM performance parts part numbers. The spindle you could cut yourself, but the brackets seem to be pretty pricy. About $252.00 p/n:12480039 not sure if that is per set or each, says 1 but doesn't explain one what. Ls1 conversion might be a cheaper deal, the C4 stuff might work with Bob bishops C5 conversion. The C5 caliper is supposed to be stronger. Bob Bishop would be the guy to talk too. Baer brakes used c4 stuff also.
Info below:
GM Racing Brakes
These modified components are used to adapt 1996 Corvette brakes to 1993-1999 Firebird and Camaro. This system is intended for racing only and is not intended for street use.
Quick Reference Charts
12480036 Suspension Knuckle RH
12480037 Suspension Knuckle LH
12480038 Bracket Cut Rotor
12480039 Bracket Full Rotor
12480042 Race Cut Rotor RH
12480041 Race Cut Rotor LH
12480043 Brake Pad Set FRT
12480044 Brake Pad Set RR 1993-1997
12520232 Front Brake Calliper Set RH Production Corvette
125205231 Front Brake Calliper LH Production Corvette
12528690 Front Brake Calliper RH Production Corvette GS
12528689 Front Brake Calliper LH Production Corvette GS
Back to Top
