26in.x 10.50in.x 16in ET Streets fit 16x8 wheels?
Hey guys im looking into getting some MT ET street tires and was wanting to put them on my stock 16x8 wheels..Will they fit good or will i have problems with them? Would it be possible for me to run 11.50 wide on an 8 inch wide wheel? or is that just out of the question
Also those of you running these how do you like them? and just to make sure, they arent tube tires correct? Thanks
Re: 26in.x 10.50in.x 16in ET Streets fit 16x8 wheels?
I had 26x11.5 on a stock Firebird 16x8 and it worked fine with no tube.
Mickey Thompson recommends tubes, FYI.
Most people run without them, but if you want to drop the pressure below a certain point (not sure of what point that is) you will need tubes.
Thanks guys, im not going to be able to get them this month like planned, im going to try to treat my self to a set for christmas. If the 26x11.5's fit, i would much rather have them. So where is a good cheap place to get them at? and will a normal tire shop mount them?
Moshbmx1
Jan 20, 2015 03:27 PM
