metallic grinding noise 99 Z28
Old Oct 27, 2004 | 07:05 PM
cobrakillr718's Avatar
99 camaro Z28 5.7 liter V8/Auto/12,000 original miles.Theres a metallic grinding noise coming from the left side of the engine. The metallic grinding sound stops when I either put on the A/C or defogger. So to recap I hear metallic grinding noise...and when I put the A/C or defogger on I then hear the clutch engage and the metallic grinding sound goes away. It immediately comes back on when I shut the A/c or defogger off. I noticed the belt tensioner on the top left of the engine shakes. I put more tension then less tension and the noise is still there. I dont believe its the belt but its possible.Maybe a pulley is loose or needs replacement. Maybe its the tensioner pulley. I dont have any idea. Any advice? Thank you so much in advance. Please reply to cobrakillr718@yahoo.com
Old Oct 27, 2004 | 08:13 PM
n2ceptor's Avatar
Re: metallic grinding noise 99 Z28
Might be the clutch on the A/C compressor going out.... Or the bearing on the tensioner, possibility....
Noenav
Mar 1, 2019 07:38 AM
vb95z28conv
Jan 27, 2015 08:32 AM
Deadbolt24
Jan 19, 2015 01:29 PM
thenewkid
Nov 27, 2014 09:41 AM
squarehead
Nov 21, 2014 08:02 PM
