Replacing 2001 Z28 Front Turn Signal Bulb?
Old Oct 27, 2004 | 06:31 PM
StevenGoodman's Avatar
I just got a very nice 2001 Camaro Z28. I like it a lot. The only little problem is a burned out front turn signal bulb.
How do I replace it?! It seems I need to be triple jointed? I can barely see the socket thing, but it isn't obvious how it is supposed to come out?
Hopefully I don't need to remove the headlights? Or should I just take it to my mechanic or a dealer?
Old Oct 27, 2004 | 06:46 PM
Kataklysm's Avatar
Re: Replacing 2001 Z28 Front Turn Signal Bulb?
Climb under there and grab the base of where the wires run into, it should be plastic. Turn counter clockwise and it will pull out after that, then just pull out bulb, replace and reinsert back into the signal cover.
Old Oct 27, 2004 | 07:33 PM
SFB767's Avatar
Do exactly what he said, but first remove the splash panel, which is held on by about 8 bolts.
Old Oct 27, 2004 | 07:44 PM
Kataklysm's Avatar
They put one on there? On the LT1 styles it was all pretty much open, the nose just kinda curved back and up to protect it a little bit.
Old Oct 27, 2004 | 11:25 PM
BirchMan98z's Avatar
I always do it from the top. takes a bit of patience, but it's quicker than removing the splash guard and doing it from the bottom.
Old Oct 28, 2004 | 01:37 PM
Thanks everyone, I will try again this afternoon.
I can't access the bulb from below, the ground effects are too close to the ground. And the ramps I have for my pickup are too steep. But I could go to my mechanic and put it up the lift.
However, it does seem barely accessable from the top; if you remove the one simple bracket between the engine area and the headlight assembly.
But the "socket" holding the bulb doesn't want to turn; is there any kind of little clip or something locking it is place? I can't really see the socket. Is there an identical socket elsewhere on the car that I could look at?
Old Oct 28, 2004 | 04:19 PM
RobertoZ28's Avatar
yes you need to push the clip in and turn. It's kind of a pain, but it can be done from the top. If you don't have skinny arms, I'd remove the splash pannel, other wise you will cus up a storm trying to get it.
believe me, I know, my car got backed in to last year, and it doesn't seal right. So I get all kinds of moisture/water in there. It burns out about every other month. I'm just too lazy to figure out where the water is coming in.
Old Oct 28, 2004 | 06:49 PM
Got it! I parked it in the bright sun, and I could barely see the socket, and the important little clip by looking through the gap between the headlights. I did need to remove the bracket between the engine area and the headlights to be able to reach in; and even then it was still real hard.
What is the splash panel everyone is mentioning? There was nothing else obvious that could have been removed; except maybe the headlights or the whole front grill/cover/whatever it is called. And none of those looked easy.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
Jon657
Jul 19, 2002 07:51 PM
