Dreaded Rear Hatch Squeak!!
Old Oct 26, 2004 | 07:38 PM
99TransAmWS6's Avatar
This is so annoying!!! I cant stand it!! is there any way to stop the rear hatch frome squeaking? everytime i drive i hear it..unless i turn my radio way up..its so damn annoying. Not to mention the way the hatch sounds when you go over a bump..i tried moving the latch assembly..and it still didnt help..any fixes?
Old Oct 26, 2004 | 08:46 PM
Re: Dreaded Rear Hatch Squeak!!
yea i tried the stops rob..didnt help..im pretty sure its the hatch..i dont have the spare/jack..or anything back there.
Old Oct 27, 2004 | 04:33 AM
AL SS590 M6's Avatar
Moderator
Use some sillycone spray.
Old Oct 27, 2004 | 07:30 AM
nikkev's Avatar
I know this sounds really ghetto, buuuuut.....
Take some electrical tape and wrap it a couple of times around the U shaped bar that goes down into the latch. If it's your hatch rattling then this will stop it.
Old Oct 27, 2004 | 08:40 AM
MikeyG's Avatar
Do you have subframe connectors? I don't have any squeaks or rattles anymore...
Old Oct 27, 2004 | 11:32 AM
no subframes yet..that'll be in the winter mods list.
Old Oct 30, 2004 | 12:36 AM
99 z28 Haas's Avatar
i got subframes and my hatch will occassionally squeek when i got the windows down and im on the highway or something. i agree, it is ridiculously annoying
Old Oct 30, 2004 | 12:46 AM
sprayedtransam's Avatar
This sounds really super ghetto. but I swear by it. Get a bar of soap and make sure it has a little moisture, and rub it on the rubber on the hatch and it won't squeak anymore. I thought the idea was bogus the first time I heard it, but try it and you will be a believer.
Old Oct 30, 2004 | 09:01 AM
Mindgame's Avatar
Question Re: Dreaded Rear Hatch Squeak!!
ENGINE Tech?
-Mindgame
Old Oct 30, 2004 | 01:33 PM
Loading's Avatar
I have the squeek as well, and it's really really bad. I've been looking for a few days now, I've adjusted every single screw/bolt I can think of.
I will try the electrical tape idea, I'm not sure if I wanna rub soap all over the rubber. Are you positive soap is 'ok' for use on the rubber stuff?
Old Oct 30, 2004 | 02:03 PM
blackbirdta's Avatar
i like the electrical tape idea...i dont notice rattles and sqeaks much EXCEPT the damn hatch every time i hit a decent bump...sounds like the car is falling apart
Old Oct 30, 2004 | 09:33 PM
Johnny-Z-Man's Avatar
Hey Bro,
I had my Z almost 10 years and will tell you your problem is the latch itself and would need to be replaced because the rubber coating is warn out.
Like someone said in the above post, wrap a little electrical tape around the striker that the latch hooks onto, and that band aid should last 6-9 months!
Trust me it works excellent!!!!
Old Oct 30, 2004 | 09:44 PM
Originally Posted by Johnny-Z-Man
Hey Bro,
that is does....i stuck some on today and works great so far
Old Oct 30, 2004 | 10:06 PM
Loading's Avatar
Sounds excellent. I just adjusted the latch thingy, so now it's down quite a bit lower. Very hard to get the hatch to close now, but I"m hoping it'll hold it down nice and tight. I also put a tiny bit of electrical tape around the striker thingy. How much tape did you guys use? Wrap the entire striker (sides included) then do a second pass or what?
Old Oct 30, 2004 | 10:10 PM
You don't need to wrap the sides. Simply use a thin coat, one pass and make it tight.
