SMUJeremy
10-18-2004, 11:06 PM
My car has developed a metal popping like sound when I am at low speeds and braking or taking off slowly. I just would like to know where to start first.
Thanks.
Thanks.
Suspension Clanking/PoppingSMUJeremy 10-18-2004, 11:06 PM My car has developed a metal popping like sound when I am at low speeds and braking or taking off slowly. I just would like to know where to start first. Thanks. n2ceptor 10-18-2004, 11:08 PM Location???? Front/Rear????? Right/Left side????? SMUJeremy 10-18-2004, 11:32 PM Location???? Front/Rear????? Right/Left side????? It's really hard to tell where its coming from. SMUJeremy 10-21-2004, 09:08 PM I have been listening a lot closer and I believe I have it narrowed down to the rear definately, 75% driver side. n2ceptor 10-21-2004, 11:11 PM Worn-- shock, LCA bushings, end link bushings... Possible sticking caliper.. Loose bolt/nut... Check the U-joint also..Just in case... Worse case-- Limited slip(aka: Posi) going out.. Mine make a popping/grinding sound when it went out... But it made the sound most prominate when backing up and turning at the same time, slowly..... :) Zepher 10-22-2004, 03:37 AM May be the torque arm mount. Mine is bad and you can hear it clank if you tap the gas to make the car lurch a bit, it also clanks when I back out of the driveway. I just put a new Energy Suspension mount on the car this evening, but didn't drive the car yet. SMUJeremy 11-08-2004, 04:28 PM I found the problem. I noticed my driver rear tire was running low, so I took it up to Discount tire, and they found 2 nails in the tire. They repaired it for free and guess what....no more sounds. | ||
