Question about orange thread sealer on GM parts........
ACE1252
10-18-2004, 09:38 PM
I'm curious about what type of sealant that GM uses on some of it's parts. In particular, the sealant used on coolant sensors and the fittings that connect the oil pressure sensor on the back of the engine.The reason I need it is because I thought I had overtightened the oil pressure sensor(ie stripped threads). So I took the fitting that sensor connect to loose to check the threads. The threads looked great and now I can't tighten it up and have the the oil pressure sensor hole sit in the right location. So I assume that I need that sealer to seal it up and lock the fitting in place.
The only thing I can tell is that it is orange. That stuff must also serve as a type of thread locker, cause it was tough to break loose and now given the same amount of turns I used to take it loose...it will not tighten up. Anyone know anything about that orange thread sealant????
ACE1252
10-18-2004, 10:11 PM
I've been doing some searching, is this what I need?
http://www.permatex.com/products/industrial_individual_products2.asp?selectid=142&category=thread%20sealants&oe_category=engine&product=Permatex,%20High%20Performance%20Thread%20 Sealant
ACE1252
10-18-2004, 10:14 PM
This kinda looks like it.....
http://www.longlok.com/products_vibraseal.htm
Can someone confirm if this is the stuff on the threads of some GM parts?
Dave89IROC
10-18-2004, 11:01 PM
vibra-seal is what comes on the threads, it looks like that permatex stuff is for the aftermarket sevicing as a vibra-seal replacement, so, get some of that permatex stuff and tell us how it works
Spinner
10-18-2004, 11:08 PM
I use GM thread sealant.
ACE1252
10-19-2004, 12:18 AM
Thx for the confirmation and advice on what to use guys. I got some Permatex High Performance Thread Sealant(PN#56521) on order. I'll let ya know how it works. :)
