camario
10-02-2002, 07:10 PM
Hey guys, I originally wanted to put an LT1 in my 92 rs, but due to the funds i am gonna pick up a rebuilt 350 but I need some input: :confused:
1) Can i put tpi system from a 305 onto a 350?
2) Will my 92 rs transmission(rebuilt 1 yr.) handle the 350?
3) Anything else i should know?fuel,cooling,etc.
91RS5speed
10-02-2002, 07:35 PM
1 yes but depending on how built the 350 is you might want to change the injectors and get a chip made for it.
2 agian depending on how build your new engine is and what trans u have.
3 if everything is in proper running order you should be ok.
aklim
10-02-2002, 11:48 PM
You will need a chip. I believe the cam is different and so is the displacement. Further to that the 350 uses a 22 pph injector while the 305 uses a 19 pph injector. I highly recommend www.fasterproms.com as I have used their product. The craft one roughly for you based on your specs. you run it and take readings and the reburn it. Do it again and they give you the finished product all nice and neat. Car has no down time once the first chip comes. It is not cheap. $500 for the first time it is done. Years later when you do other stuff, each time they have to redo it, it costs $150.
