NineD3Z
10-17-2004, 07:53 PM
Ill make this short. I have Jethot LTs and Eibach Pro-kit. I hit a bump/dip in the road very hard on my passenger side header. The two bottom tubes are bent in or crimped like 1/4 inch or so. What are my options other than replacement Can i buy only one header from Jethot? Is there a way i can get them bent back? Also how badly would this affect performance. Thanks in advance.
Birdman7389
10-17-2004, 08:07 PM
Call up jethot and ask for Chris, explain your problem and I bet you will get a fair price on a new one......
NineD3Z
10-17-2004, 08:59 PM
Thanks, but before i resort to having to buy a new header. I need to know if this one will be ok, or if it can be fixed.
Birdman7389
10-17-2004, 09:24 PM
pics? Might be able to have an exhaust shop pull it out.
NineD3Z
10-17-2004, 09:26 PM
Ill have to take pics in the morning. Its too dark out there now. Thanks.
Z95m6
10-18-2004, 12:59 AM
you might be able to put a pry bar in the collector and push the dents out. I did this with a set of used long tubes i bought for my Mach 1. I had to heat the tubes though in the area to get them to bend out, i did this before i had them coated though. If not body shops have special tabs they can spot weld on and use a slide hammer to pull dents out of cars. I'm sure they could do it to your header. Once again the coating will be ruined.
