11 sec LT1 do I need suspension upgrades?
Old Oct 17, 2004 | 03:20 PM
97silverTA's Avatar
I have a 97 lt1 TA 6 speed. I run 11.61 @ 119.5 and a 1.64 60'. This was on ET Streets. The weird thing is that I don't have a single suspension upgrade on it. The car is stock when it comes to suspension. I don't have subframes, LCA's, or anything. Do you think I could run a better time with any suspension upgrades even though my 60' is decent? I can really feel the car flex every time at the track. Thanks for your help.
Zach
Old Oct 17, 2004 | 04:51 PM
Red96Lt1's Avatar
Re: 11 sec LT1 do I need suspension upgrades?
That's an impressive 60' with just tires.
I would put SFC's first, then LCA's cause they are cheap and you will feel the difference. If you have $400, get a TA that mounts to a xmember. Like the BMR trac pac.
Old Oct 17, 2004 | 05:52 PM
LT1Squirrel's Avatar
SFC's and LCAs will help a lot in the flex/launch/rear breakage
Old Oct 17, 2004 | 05:55 PM
97silverTA's Avatar
Will SFC's and LCAs really help my rear end not to break as easily? I heard that if your car has a lot of flex, you loose power? I think I had a good 60' because I launched the car on a 150 shot
Old Oct 17, 2004 | 06:00 PM
SFC's will cut down on flex= harder launch
LCA's will give you more weight transfer=better traction=harder launch
harder launch= more unhealthy for the rear
Old Oct 17, 2004 | 10:59 PM
Red96Lt1's Avatar
Yeah, I would say unhealthy for a 10 bolt, but a LT1 is also unhealthy for a rear end
Less flex in the LCA and stiffer bushings, help traction alot. SFC's keep the car from flexing and energy being dissolved in the chasis.
Old Oct 19, 2004 | 09:22 AM
SnakeKilla's Avatar
For how long have you had that 10 bolt 4:10 gears and et streets?
It is very impresive that you rear is still holding. Are those et streets bolt to your stock rims?
Nice times man !
Old Oct 19, 2004 | 01:43 PM
97silverTA's Avatar
Nice times man !
I have only had this ring and pinion for about 2 weeks. I cut 1.6's on my first set of 4.10's and they didn't break at the track, but somehow I wore groves in the ring and pinion? So they whined so loud you couldn't here the radio on full blast I have the et streets on some stock 16 inch TA wheels. I am also surprised I haven't broke any teeth off my ring and pinion. I also have the autozone lifetime guaranteed clutch and it is holding
Old Oct 23, 2004 | 03:16 PM
RallyRed701/2's Avatar
so what kind of gains would somebody with no suspension mods see after sfc and lca's? are they really worth the money?
Old Oct 26, 2004 | 12:17 AM
crazy_jackalope's Avatar
stupid quick question- What are SFC's
Old Oct 26, 2004 | 01:00 AM
1KillerV6's Avatar
Sub frame connectors....there and many kind. box tube , round tube (usually yeilds more clearance). Bolt in , weld in Some are diamond shaped and some are just a bar as you can see.
Old Nov 14, 2004 | 06:00 PM
Red96Lt1's Avatar
That's like asking if traction will help and is traction worth the money.
YES!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
jp2002ls1
Aug 6, 2002 11:15 AM
