SkillZ25
10-17-2004, 01:44 AM
Ok i am getting a CSR electric water pump (From summit) and I was wondering if I am going to need anything else for the install...
Water pump question...SkillZ25 10-17-2004, 01:44 AM Ok i am getting a CSR electric water pump (From summit) and I was wondering if I am going to need anything else for the install... Kryckter 10-17-2004, 02:07 PM Maybe some wire and connectors. Summit sells a electric water pump instal wiring kit that makes the wiring easy. You will need a dremel or grinder to clearance the water pump housing. A big hammer to knock out the internals. Other than that....no extra parts really, You will need some antifreeze and water pump gaskets. SkillZ25 10-17-2004, 04:58 PM cool thanks SkillZ25 10-17-2004, 05:06 PM Wait do I have to get that install kit from summit or is there anywhere else I can get it? Birdman7389 10-17-2004, 07:17 PM just do a search on here for elec WP install, there is a good write up. And if you have any kind of electronic or wiring skills you wont need the kit from summit. It's pretty straightforward and there is a schematic included in the write up I was talking abot. SkillZ25 10-17-2004, 10:54 PM Yea I did a search and saw that link and also I talked to a guy from summit and he said I dont need anything extra so i'm gonna give it a shot without the wiring kit. Also is there any "better" brand of antifreeze coolant cuz im gonna flush my radiator also. Birdman7389 10-17-2004, 11:43 PM Just regular "dex-cool" is what I run. SkillZ25 10-19-2004, 02:34 AM :cool: Thanks for the help | ||
