Put new clutch in... still not working..
Old Oct 15, 2004 | 07:17 PM
wonbadassz28's Avatar
Soooo I had a problem with my 96 Z28 that i just bought a week ago, i had it TWO days, and it left me stranded in the middle of the road, wouldn't go into gear, and when i finally got it into gear, the gears just grinded. Soo i put a new clutch in today and what do you know, it STILL doesn't go into gears... any suggestions as to what the problem may be??!?
Old Oct 15, 2004 | 11:56 PM
IllusionalTA's Avatar
Re: Put new clutch in... still not working..
how does the pedal feel? you positive the cluthc fork is on the t/o bearing completely? prior to getting "strandeD" what were your driving habit's? what kind of shifter do you have? are the stop bolt's up against the shifter?
Old Oct 16, 2004 | 09:00 AM
im almost 100 percent positive the fork is on the TO bearing the entire way, the pedal feels normal and solid, before it broke on me i was babying it, about 45 miles on the highway in 6 gear at about 75 MPH, got off the high way downshifted to a stop like 2 times, then its when it happened
thanks man
Old Oct 16, 2004 | 04:09 PM
firstz's Avatar
is the slave and master cylinder leaking mabe you got air in the lines so its really not disingaging the clutch. also do you hear alote of noise just leting it sit there in nuteral?
well i hoped i helped
Old Oct 16, 2004 | 04:20 PM
i dont hear any noises when its in neutral and even when i muscle it into gear it only grinds a lil bit, im gonna try and bleed the system down tomorrow night and see what happens, thanks for the help guys
russ
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
Ryabut98
Sep 3, 2002 11:45 PM
