do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
zo6vette
10-10-2004, 08:04 PM
i have a tci deep transmission pan and i was wondering if you have to upgrade the transmission filter? do you use the stock trans filter one or do you have to use a longer transmission filter with a longer neck due to the larger pan?
Timberwolf
10-10-2004, 11:51 PM
fluid level is still the same when full, so the stock filter will be fine.
