Fans come on when jumpered, but not while driving
Old Oct 10, 2004 | 04:52 PM
Andrew04ME's Avatar
I can turn both fans on if i jumper them using a paperclip. They will come on when i have a SES light. But they wont come on when i'm in traffic and the needle heads to the red. Relay problem?
Old Oct 10, 2004 | 09:40 PM
Compstall's Avatar
Re: Fans come on when jumpered, but not while driving
Try the temp sensor mounted on the water pump first. It's only ~$10.
Old Oct 10, 2004 | 10:06 PM
Kataklysm's Avatar
Ahhh I had the same issue. First check the fuses, then I'd move onto relays. If its not those it could possibly be the fan motors drawing to much current. Or, like my case, theres a loose connection. I was fiddling with the fuse block, EGR, O2s and EVAP and it worked. Don't ask me which was the culprit though
Old Oct 10, 2004 | 11:46 PM
Andrew04ME's Avatar
All the fuses are fine. Is their any visual indicator that tells if a relay is bad?
Thanks,
Andrew
Old Oct 11, 2004 | 08:22 AM
Kataklysm's Avatar
No, you can't visually see a broken relay unless it somehow cracked I suppose. Try rearranging the relays to see if the fans work with say the air pump relay. If they still don't work with the other relays then its not the relays.
Old Oct 11, 2004 | 01:50 PM
Andrew04ME's Avatar
I'll try that, thank you...
ChrisFrez
Feb 22, 2015 08:47 AM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
