Those with LS1 center consoles in LT1's, how did you fill the space?
dmoor88
10-09-2004, 04:43 PM
Im about to put an LS1 center console in my 1995 Z28. I was wondering how some of you filled the space between the console and the bottom of the radio bezel. At some point I'd like to completely swap my LT1 dash out for an LS1 dash, but for now I'm looking at what I can fill the space with.
gunter96ws6
10-10-2004, 11:25 AM
you dont have to, it looks fine with nothing there~gunter
AW/whiteZ-28
10-10-2004, 12:20 PM
I'm gonna mold a dual gauge pod to the bottom of my radio bezel to fill that space up
meissenation
10-10-2004, 02:59 PM
Currently I have a large fluffy black snow hat shoved in there, it fills in the space and hides all the wires and it's not that noticable. My ultimate plan, though, is to finish working on a comp I have and then mold the 10.5" touchscreen panel into the LT1 radio bezel, which would lengthen the bezel down to the LS1 console.
dmoor88
10-28-2004, 04:49 AM
T T T
94BlackBowtie
10-28-2004, 08:59 AM
I know several have used this piece from a Mustang.
http://www.stangparts.com/products/partpic.cfm?TypeID=20&ID=2837&Page=5&ShowSpecials=FALSE
dreamer1q comes to mind.
Here's the best pic I could find.
http://www.dreamer1q.michiganspeed.com/2003/DSC01941.JPG
mike96lt1
10-28-2004, 12:35 PM
Hey did anybody do the swap that had traction control, if so what did you do with the switch?
Fallchild000
10-28-2004, 08:58 PM
I also have a question. I switched in an LS1 T/A console in my 95 T/A, and the only thing that didnt match up was the Cigarette Lighter Connection. Does anyone know of an adapter I can use?
nathan
'96SS1524
10-29-2004, 01:48 AM
i have wanted to do the console swap and mold a piece to house a police scanner and a cb maybe (maybe not on the cb), is this my southern influence trying to escape? i think it would be cool.
94BlackBowtie
10-29-2004, 06:39 AM
nathan
It is covered in this guide.
http://www.mindspring.com/~nvader/index4.htm
AW/whiteZ-28
10-29-2004, 10:49 AM
Why not just use you old cig lighter base?
94BlackBowtie
10-29-2004, 03:16 PM
No room.
The newer console goes down and sits higher "underneath" where the old cigarette lighter base/cassette holder would be.
AW/whiteZ-28
10-29-2004, 07:02 PM
No I mean since the plug won't work with his cig lighter that he should get the old cig lighter out and swap em so the plug will work.
I already have my idea for the space filler as you can see above :D
(My first post on this thread)
94BlackBowtie
10-30-2004, 07:12 AM
(My first post on this thread)Where's the head smacking smiley when you need it? :D
Well - you could do that - but then you still have to make the other accessory plug work (if you want it too). Might as well just go through the trouble there instead of removing/replacing I guess.
LET'S JUST DO ALL THE THINGS YOU WANNA DO!
AW/whiteZ-28
10-30-2004, 10:10 AM
Well since we got that straight! :D
I just used 2 female spade connectors and some similar gauge wire spliced into the pre-existing cig wires.
