NoFear95
10-06-2004, 08:30 PM
Another reason why I love my wife. She got it for me as an early B-day gift!
http://home.comcast.net/~j.burks/Strutbrace/DSC01400.jpg
http://home.comcast.net/~j.burks/Strutbrace/DSC01407.jpg
http://home.comcast.net/~j.burks/Strutbrace/DSC01409.jpg
GreenDemon
10-06-2004, 10:13 PM
Your A/C and brake lines could use some work...
J/K :p
Nice work man :thumb:
Hopefully someday mine will look that clean.
tavella
10-06-2004, 11:57 PM
Is there anything special you have to do to put on the strut brace bar or do you just remove the bolts and slip it on? I don't want my car to fall apart and hit the ground if I mess something up.
NoFear95
10-07-2004, 08:59 AM
Yea all the rest of it will get polished out next year if and when I pull the motor. Seen an LS1 all polished up and it gave me motivation. Not to many chromed/polished LT1's out there.
Nothing special to putting it on. Nothing will fall out if you remove the two nuts on each side to put the brace on. Just keep the brackets loose until you bolt the bar in. Then tighten up the brackets and your done. Shouldnt take more then 15 minutes if your being careful.
XxXTransAmXxX
10-11-2004, 01:56 PM
<----- This guy has a FULLY POLISHED LT1, Block, Heads, Waterpump, Intake, & ALT...
NoFear95
10-11-2004, 02:45 PM
Email me some pics, Ill host them for you.
Doppleganger
10-11-2004, 03:02 PM
The alternator seems to fit more flushly in the engine compartment than on my LT-1, is that some kind of aftermarket bracket?
Also, what technique did you follow to polish the alt. ?
NoFear95
10-11-2004, 03:11 PM
Stock bracket. FRC might be throwing you off.
Bought the Alternator chromed from Mr. Alternator.
