nitrous fuel plumbing
Old Oct 4, 2004 | 01:03 AM
17WITHaBIRD's Avatar
I am going to be installing my nitrous kit soon and I need some help with the fuel part. Im pretty sure I run the fuel line from the back of my fuel rails, there is a fuel pressure valve that is capped off. Do I need to remove just the cap and then run the fuel line to the solenoid or is there a valve or something else that I need to remove besides removing the cap?
Thanks,
Matt
Old Oct 4, 2004 | 02:33 AM
bazzi's Avatar
Re: nitrous fuel plumbing
Just remove the cap and run the line off that. thats how i got it and im pretty sure thats how it goes
Old Oct 4, 2004 | 06:13 AM
RacinLT1's Avatar
yes,you also need to remove the schrader valve inside that port. just screwing the nitrous line after you remove the black cap wont do anything.
Old Oct 4, 2004 | 06:57 AM
jeremyferguson's Avatar
Thanks,
Matt
LT1racin is correct. go to an auto parts store and get a valve stem core remover, its like .99 cents and it will work perfectly.
Old Oct 4, 2004 | 04:41 PM
thanks...ill let you know how it goes
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
