383 stroker help
bazzi
10-03-2004, 02:04 AM
hi, i downloaded some files that are in the bin format and i want to convert them to the LT1 format. how do i do this? i got a 383 stroker, stock heads that have been hoged out with a mild cam. im running a wet nitrous kit with a 175 shot. i want to look at the files to give me a guide line on how to tune my car. do u have any suggestions on how i should tune my car and where to start?
thanks,
baz
smoknta
10-03-2004, 07:21 AM
bin format is what the LT1s use.....you just need some software to read it
I use datamster for my 93
smoknta
10-03-2004, 07:22 AM
sorry....i meant Tuner Cat
bazzi
10-03-2004, 03:55 PM
so where can i download the tuner cat?
smoknta
10-04-2004, 11:30 AM
www.tunercat.com
Dan K
10-05-2004, 11:39 PM
According to your sig you already have LT1 edit...
If that's the case and you're trying to open a bin file I don't think that LT1 edit will open it. Someone wrote a program that converts LT1 Edit files to bin files and vice versa.
If that's all you need, do a search for it and you should find a link to it.
bazzi
10-06-2004, 05:12 AM
okay thanks. my car is running alittle lean right now. i change the a couple things on the spark table and thats all but now my car is running a little lean. should i just use the pe tables to richen it up
Dan K
10-06-2004, 09:56 PM
Depends on where it's rich. WOT? Idle? Part throttle?
