1984camaroz28
10-02-2004, 05:19 PM
WIll i need to clearance to fir this combo. This is the rite tire/rims combo i need to get my car to hook
28in tall tire 10in wide rim clearance????1984camaroz28 10-02-2004, 05:19 PM WIll i need to clearance to fir this combo. This is the rite tire/rims combo i need to get my car to hook 1984camaroz28 10-03-2004, 08:29 PM ttt kandied91z 10-04-2004, 01:47 AM depends on your offset wheel. what is the offset backspacing? the width of the tire too? not enough info. i had 195/35/18 on a 10 with 6.75 nad it was perfect. if your going to run taller i'd suggest stepping out futher at least an inch or so on the bs. aziroc 10-04-2004, 07:35 AM i was going 2 go with a 28 in tall tire, but went with a 26 (ET Streets 26x11.5x15) by backspacing is whatever the stock size is, and i BARELY get rubbing on the outside.. but ever since i rolled the fender it was fine... but if i went with a 28" tire, it would b shreded. 1984camaroz28 10-04-2004, 02:01 PM Weld Draglite 15" x 10" rear rims (5.5" back spacing with a M/T ET Drags 28 "W" with tubes and rim screws is what the spohn car is runing. Im looking to run the exact same setup looking for what i need to do in order to fit this combo in there kandied91z 10-04-2004, 03:50 PM why not email him then....or call. i'm sure he'd help you with it. | ||
