Need help with datmaster
wicked_95z
10-02-2004, 09:17 AM
I can monitor data but when I try to record no data is present on the laptop but it says its recording? Any help?
Alvin@pcmforless.com
10-02-2004, 10:17 AM
wow, I would try a reinstall.
jonota
10-11-2004, 06:51 AM
have you enabled autologging?
Jonota
wicked_95z
10-11-2004, 10:07 AM
I havent changed anything since install
jonota
10-12-2004, 07:39 AM
with datamaster, to be able to actually record a file and recall it you either have to make a file (complicated) or enable autologging, which will automatically make a file for you when you press the record button. Check into it in the help file of datamaster
Jonota
wicked_95z
10-19-2004, 08:43 PM
Okay, finally had time to mess with it and still nothing. I tried a reinstall, I enabled and disabled autologging. I can however take a single frame recording but no continuos recording and it still says recording data at the bottom of the data screen. Here's how I try to record.
Open data master-go to file and to record aldl data- on the data acquisition screen I open a new file and give it a name and hit enter. And nothing. I have to assume my cable and port are good cause I can monitor and read my pcm with tunercat. Any help would be great cause I think I have a real problem but cant datalog to findout. Left o2 sensor is reading 78mv on single frame :eek:
jonota
10-19-2004, 08:48 PM
Here:
Open datamaster
File->Record ALDL data
If recording is not on, hit the button to turn it on
If autologging not enabled, enable it OR make a file name
In the bottom left (sample control center) you must hit START to begin recording
When done recording, press stop. Top bar of the window will tell you the file name for reviewing it later.
Jonota
