List of fastest LT1's
Pages : [1] 2
meengreen 94z
10-01-2004, 01:04 AM
Quickest LT1's list
Power Adder list (10.49 and under)
“Big Rick” Rick Intrau- Current Fastest LT1,Took the title on November 7,2004
1996 Formula WS6, 396ci LT1, AFR 215rr heads, 91.5mm Turbo, Madman suspension
¼: 8.08 at 172
Lisa33(Non 4th Gen)
383LT1, maxed out procharger F1, ported TFS heads, Bret Bauer cam, half filled block, JW PG, 8 3/4 3.91 rear end, 12.5x30-15 slicks
60 ft.:1.25
1/8:5.42@128.6
1/4: 8.54@151.6
Chris Sikora “Z8’s”- took the Fastest LT1 title on October 18, 2003
383ci LT1, AFR 220cc heads, Vortech YSi trim
¼: 8.928 @152.61
1/8 5.750 @123.96
60 foot: 1.341
George Baxter-held fastest LT1 record, November 2001
1997 Camaro SS Convertible, 383ci LT1 with YS-trim(?)
¼: 9.04 at 155.33
Jeff Gilbert
96 TransAm raceweight 3556# 398 D1 procharger 100 shot
60ft1.36
1/4: 9.06@151.48
1/8: 5.82@121.1
Brian Edwards 1989 Camaro RS (NON 4th gen., stock suspended)
360ci LT1 w/ nitrous
¼: 9.06 at 148
60 ft.: 1.27
Vince McCauley “Spray the way”
383 LT1 AFR 227cc heads, solid roller w/ 350 shot
¼: 9.08 at 159.79
Taner Bosnali
1996 Camaro SS- Fastest 4th gen LT1 6-speed
399ci LT1, AFR 227cc heads, Nitrous, T-56
¼: 9.08 @ 155.07 mph
60 foot: 1.425
Dave Diluca
1994 Camaro Z28-took the title as fastest LT1 on July 2, 1999
396ci LT1, w/ nitrous, powerglide
¼: 9.11 at 154.59
1/8: 5.87 at 120.88
60 ft.: 1.36
Dave Ducote/Madman- held the fastest LT1 record,
1994 Formula, 381ci LT1, ATI Procharger 20psi, TH400
1/4: 9.18 at 152 (October 2001)
Ric Fleck "Tubby"
1997 T/A
F1 procharger w/ small nitrous shot
1/4: 9.20@ 145.9
60 foot: 1.27
Brady Mcnew
1996 Camaro Z28
1/8:5.91 at 112
60 ft.: 1.49
Jay Billingsley,
1993 Z28
9.29? at ??? (more info needed)
Jason Warren
1995 Camaro Z28
350ci LT1, Trickflow heads, w/ 300 shot of nitrous
¼: 9.33 @ 142
1/8:5.87 @ 117
60ft.:1.28
Voss Boreta.- QUICKEST IMPALA SS
96 Impala SS
383 LT1, F1R Procharger, TH400, 3000 Stall, 3.50 Rear, 4150# raceweight
1/4: 9.394 @ 149.03.
60 ft: 1.56
Rob Cowling “Yellow Z28”
Camaro Z28
383 LT1, AFR 227cc heads, 85mm turbo, TH400,
¼: 9.34@149
1/8: 6.079 @ 120.55
JM385LT1
1996 T/A
1/4: 9.404 @ 141.79
1/8: 6.001 @ 116.06
60 ft: 1.37
Stefan D.
1993 Trans Am
396ci LT1, LT4 heads, stock pcm, nitrous
1/4:9.41 at 141.12
Lisa33
1995 Camaro Z28
F1-SC ported TFS heads 17psi FMIC 4l80e 3000 vig
1/4: 9.44 @ 143
1/8: 6.02 @115
1.69 60ft
Jeff Stevens
1996 Camaro Z28, 383ci LT1, Vortech YS trim
¼: 9.47 @ 148mph
1/8: 6.34 at 112.05
Camaro Z28
383 LT1, AFR 227cc heads, YS trim (now YSi trim), TH400, 712rwhp at 19.5psi
¼: 9.52 at 142
1/8: 5.98 at 116 (around a 9.20 at 147-149 in the ¼)
60 ft.: 1.30
Tony Shepherd
93 Z28
397 LT1, solid roller, AFR 227 , 250 shot, 3450 lbs, TH400,
9.56 @ 143.68 mph
1.42 60ft
Ralph Olivarez/Madman
1994 Camaro Z28
355 LT1, LT4 heads, TH400 w/brake, ProCharger D-1, FAST system, Madman suspension
1/4: 9.56 @ 141mph
"JeffB94z"/Induction Motorports
1994 Camaro Z28
396ci LT1, Vortech T-Trim, 50 shot, TH400, F.A.S.T. EFI
1/4:9.57 @ 142.7
60 ft: 1.35
Darren Nichols "Chevyguy3”
1995 Pontiac Formula 396, cam 254/259, .664/.656, 112LSA , "Stage 3" LT4 heads 2.00/1.60 valves, 279cfm , TH400, w/ 200hp shot nitrous
¼: 9.63 at 142
Jim Moran "INTMD8"
1997 Camaro SS- 6-speed
357ci LT1, 9.2-1 comp. AFR 195cc heads, 218/218 cam, Twin GT61's, T56, 847rwhp 847rwtq,, raceweight at 3,740lbs.
1/4: 9.68 @146.40 mph
"BigkevC5"(car now owned by East Coast Supercharging)
1997 Camaro Z28-Stock Bottom End record holder
350ci LT1 w/ LT1 ported heads, Cam, boltons, 150 shot
1/4: 9.75 at 139
Daren Wlodarczyk
1996 Trans Am WS6 Convertible
398ci LT1, AFR 227cc heads, 300shot of nitrous, 811rwhp and 928rwtq
1/4:9.763@138.49
60ft: 1.372
T/A LT1
1995 T/A RamAir, 355" LT1 ,Jet Hots,PI 3800 conv. 3.55's, CC306, Lloyd Elliott Trickflows, 3,500lbs
1/4:9.83@136mph
1.50 60'
Rick Abare
383/ported LT1 heads/intake
1/4:9.97 @ 138
Jordon Musser- 6-speed
1994 Camaro Z28
401ci LT1, AFR 210cc heads, T-56, Solid roller cam, 225shot
1/8: 6.43 at 112
Marc Rahn
383 D-1 19lbs
1/4: 10.02 @ 135.71
1.47 60 ft
OneFlyn95z28
SSEFI custom LT1,modified stock castings for heads ,LE-X heads, 200HP shot
1/4: 10.05@135.9
60 ft: 1.49
Richard Krause "rskrause"
1995 Camaro Z-28
383ci LT1, Procharger, nitrous, full emissions equipment, with "road race" type suspension, 876rwhp
1/4: 10.06 at 141.15
1/8: 6.55 at 110.52
60 foot: 1.55
Jeremy Sanchez
355 , 6spd, Gen 1 LT1 PTK kit with 76GTS
1/4-10.13@150.29
1/8th- 6.70@117.70
Matt "Nostang 96z"
1996 Camaro Z28
355 LT1 11.5-1, stock crank, 2 bolt main,GTP S2 LT4's, GTP-6 cam, 200 shot of nitrous, th400, raceweight at 3650lbs
1/4: 10.27@133.24
1/8: 6.595@107
60 foot: 1.592
Matt Swindle
'97 T/A
10.30 at 135
60 ft: 2.25
LT1Tony
LT1 396 6 Speed
1/4: 10.30 @ 131mph
60 ft: 1.42
Tony Karamitsos
1994 Camaro Z28 - 6 Speed
396 LT1 - Home Ported LT1 heads & intake, hydraulic cam and spray.
Full weight car with A/C .
1/4: 10.30 @131mph
60 ft: 1.42
Jason Brisson
1995 Z28 1LE
355 LT1, Stage II LT1 heads, hyd roller cam, TH400, Mufflex 4", 11.75:1 CR, pass made on a 150 shot
1/4:10.40@130.7
JucinGTA
1997 Camaro Z28
with a 200 shot/fogger, cutting 1.43-44s on a 10bolt, Home Ported heads flowing 250cfm, Comps Nitrous Cam, Stock Shortblock, Stock 4L60E with a Shift kit.
1/4:10.44 @129
Cody
95Z28
Twin Turbo Lt1
895RWHP corrected 755RWHP actual at 5200feet and 21lbs of boost
1/4: 10.46 @ 143
N20Dave- 6-speed
396ci LT1, CNC ported LT1 heads, 225shot, T56
1/4: 10.47 at 131
1/8: 6.70 at 103
60 foot: 1.55
FASTEST NATURALLY ASPIRATED LT1's (10.99 and under)
Joe Overton
1994 Trans Am-First N/A LT1 in the 9's- Holder of the fastest Naturally Aspirated stock susp. LT1 4th gen-Holder of the fastest 60 ft. on stock type suspension(1.249 )
388ci LT1, AFR 227cc heads, Solid roller cam, TH400 w/ transbrake
¼: 9.34@142.66
1/8: 5.93 at 115
60 ft.: 1.245
Sammy Vedros
1st Gen Camaro(non stock suspension)
396 LT1 NA
1/4: 9.62 at 13X
60 ft:1.29
Steve Quinn
1995 Camaro Z28, 370ci LT1, Ported factory LT1 casting heads, w/ race wt @ 3052
¼: 9.713@138.16
1/8: 6.277 at 108.3
60ft: 1.271
Mindgame-Fastest Naturally Aspirated 6-speed LT1
383 LT1, 15* heads, LT4 intake, T56, 570rwhp
1/4: 9.82 at 138.6mph
1/8:6.39 at 108.7
Vince McCauley
383 LT1 (carbed), AFR 227cc heads, solid roller
1/4: 9.93@135
Dave Odehnal
1993 Camaro Z28
Ported factory LT1 casting heads and intake.
1/4:10.15 at 134mph
60 ft: 1.37
Benjamin Moore III "ou812/z28"
1994 Camaro Z28
396 LT1, AFR 210cc heads, th350, stock pcm, 467rwhp and 517rwtq, 3325 raceweight
1/4: 10.18 at 132
60 ft: 1.38
N2ODAVE
396 LT1 SB2.2 heads, SR, G-Force 5 speed
10.33 @ 132.97
1.58 60'
Tim "95Bird"=6speed
T-56, 355ci LT1, ported lt4 heads, solid roller cam,Moser 9" with 4.71's .
1/4: 10.39@131.6
60ft: 1.42
1995 Pontiac Formula 396, solid roller cam, LT4 heads, TH400
1/4: 10.46 @ 128
Randy Etheridge "rje"
1.409 60ft
1/8:6.68@100.5 mph
Chrism400
1995 Z28 A4 396 Solid street roller, Lingenfelter CNC heads
1/8th 6.67 @ 102
1/4 10.52 @ 128
Taner Bosnali-6speed
1996 Camaro SS
399ci LT1, AFR 227cc heads, T-56
10.54@129.28mph
60ft.: 1.49
Clyde Moore
383 LT1, Stock head castings, TH350, Stock suspension, EFI non carb intake
1/4: 10.66@128
Dave Jones
Solid Roller 383 ,AFR 210,cam is 264/271 .688/.660,
10.73@127(1.55 60ft)
1/8 6.86@101
Dave Smith
1995 trans am- 6-speed
396. solid roller, AFR heads, 6 speed
10.76@131mph
Jordon Musser
1994 Camaro Z28- 6-speed
401ci LT1, AFR 210cc heads, T-56, Solid roller cam, 471rwhp/ 455rwtq
1/4:10.80 at 130
1/8: 6.9 at 100
Stefan D
1993 Trans Am
1/4:10.82 at 128
Travis Linville
1994 Z28 Hardtop
396 ci. Lt1, GTP Stage 3 Heads, Ported Intake, Hooker Long Tubes, Solid Roller Cam, T-56, McLeod Street Twin, Moser 12 bolt w/ 4:11's
1/4: 10.83 @ 127
"FastFatBoy"
pumpgas, drag radials
3800 lbs raceweight
383 solid roller, RHS heads, Super Vic, Elbow, Monoblade, 4L60E
1/4 mile 11.02@123.9
1/8 mile 7.02@97
60ft 1.53
Ken "Kamba93LT1"
1993 Z28
355ci LT1 ,TEA LT1 heads, hyd. cam. turbo 400 w/ brake, KTRE 12-bolt w/ 4.56, 28x9.0 slick
1/4: 10.983 @ 120.93
1/8: 6.950 @ 98.23
60 foot: 1.442
QuikSS
1995 Impala SS(clone) 383 LT1, TFS heads
10.965 @ 123.71 1/4 mile
6.994 @ 99.13 1/8th
1.537 60'
FASTEST 6-SPEED LT1
Taner Bosnali
¼: 9.27@151.20mph
1/4: 10.54@129.28-Naturally Aspirated
FASTEST BOLTON LT1
Tom Cowle
1995 Camaro
Edelbrock Suspension, MT Drag Radials, CSR ewp, Hooker lt's, "junk parts", Mike Blood transmission
1/4:11.702 at 114.30 mph
60 ft:1.55
FASTEST INTERNALLY STOCK LT1
Craig Miller/ Madman Racing
1996 Trans Am
hooker longtubes, mufflex exhaust, Moroso cold air, and a 52mm t/b. th400 with brake, 9" rear end. 150 dry NOS kit. Madman Suspension. Stock interior and all accessories.
1/4: 10.86 @120
60 ft: 1.38
FASTEST CAM ONLY LT1
Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers, Joe O custom grind cam, 1.6rr,Strange 12bolt,QT Pros, Vig3200, 3325lbs
1/4: 11.163 @ 119.86
1/8: 7.05 @ 96.00
1.49 60 ft
FASTEST HEADS/CAM LT1
James Eddy
stock ported heads and intake ,hyd.
1/4: 10.88 @ 122.81
1/8 6.90 @ 99.08
FASTEST STOCK BOTTOM END LT1
1997 Camaro Z28
1/4: 9.75 at 139
taner
10-01-2004, 08:03 AM
actually Steve Quinn went 9.70 @ 137ish at the N vs S event earlier this year!
andy katzelis
10-01-2004, 10:08 AM
Chevyguy3's name is Darren something. Hey may not want to be known. He's a local hero round here. He wuped up on my xss last time out, awsome car. He sold the car now. He'll probably chime in eventually.
meengreen 94z
10-01-2004, 10:45 AM
Thanks, I thought I remembered someone saying that, but couldnt find any proof otherwise.
meengreen 94z
10-01-2004, 10:49 AM
Thanks, I guess I'll wait until he says something then
timelord
10-01-2004, 03:58 PM
George Baxter!!
8.6 @ 160+ MPH :)
MBonZ28
10-01-2004, 05:22 PM
George Baxter!!
8.6 @ 160+ MPH :)
baxter is no longer sporting an LT1
I am not sure if Brady 9.55 was with and Lt1 either
Daren WikidTA should be up there too. I think he went 9.7s with his 97 T/A a few years back
meengreen 94z
10-01-2004, 05:23 PM
George Baxter!!
8.6 @ 160+ MPH :)
Unfortunately he doesnt have an LT1 in it anymore. His fastest run with an LT1 was a 9.04
meengreen 94z
10-01-2004, 05:28 PM
Brady ran the 9.55 on an old setup. His new setup/car was supposed to be even faster, but I havent heard much about it in a while.
Do you have anymore information about Daren "Wikid TA"? Id include him if I had an exact time and mph and more information on his car. Thanks :)
timelord
10-01-2004, 05:30 PM
OOOOOPPPPSS !!! Sorry about that,I didn't know!!!!! :o :o
MBonZ28
brady has had a few setups. think that 9.55 was with the big block
MBonZ28
10-01-2004, 05:36 PM
http://www.wideopenwest.com/~daren96ta/
meengreen 94z
10-01-2004, 05:41 PM
Doh..totally forgot about Daren's convertible. Thanks
I'll look into Brady's record, you may be correct.
yellow Z28
10-01-2004, 07:02 PM
pete adams is a gen 1 sbc...still a verry nice car :)
meengreen 94z
10-02-2004, 01:29 AM
DaveZLT1
10-02-2004, 08:09 PM
Madman's first ProCharged LT1 in the 9's ran a 9.56@141mph w/355, LT4 heads, D-1, and th400.
Injuneer
10-02-2004, 09:49 PM
George Baxter-held fastest LT1 record, date unknown
¼ mile time: 9.04 at 155.33
That pass was made in November 2001.
Hot Rod Hawk
10-03-2004, 02:02 PM
Bradys run you listed is with meatheads 540 BBC in the car on one kit.
meengreen 94z
10-03-2004, 02:40 PM
Thanks, I fixed it.
Ill leave his 1/8 mile time up seeing how it was done using an LT1 (according to his website and GMHTP). unless someone can prove otherwise.
meengreen 94z
10-03-2004, 02:44 PM
Was that the first LT1 in the 9's?
taner
10-03-2004, 04:10 PM
Steve Quinn
95' Z 370 LT1 NA auto
9.713@138.16 60' 1.271 w/ race wt @ 3052
i figured i would post it for Steve :)
neil350
10-03-2004, 06:23 PM
Theres also a couple, that dont post on boards and are local cars.
DaveZLT1
10-03-2004, 06:40 PM
meengreen 94z
No, it was just the first ProCharged LT1 to run 9's.
meengreen 94z
10-03-2004, 06:41 PM
Steve Quinn
Ok, fixed it. :cool:
FASTFATBOY
10-03-2004, 10:15 PM
How about a list of the fastest ALL MOTOR LT1's??!! Hell anyone one can go fast with artificial atmosphere. :rolleyes:
Hell I will even start, My 'ol buddy
Clyde Moore
ET: 10.66@128
383 LT1
Stock head castings
Turbo 350
Stock suspension
EFI non carb intake.
He deserves some real credit, this car has given him fits. He's a trooper. BTW that 10.60 was a shakedown pass, he wont pat himself on the back....somebody has to ;)
STEP UP CLYDE :cool:
David
taner
10-03-2004, 10:24 PM
David
ok then add me to the all motor list
10.82 @ 126.16 mph, 1.54 60' rowing the gears :cool:
but all i have to say is All Bottle........... F%&k the throttle :eek: ;)
:D
Joes94TA
10-04-2004, 04:08 PM
who needs gas....:)
taner
10-04-2004, 08:59 PM
some of happen to have grown very fond of the bottle in our younger days, i just never thought i would come back to it at such an early age :D
Joes94TA
10-04-2004, 09:45 PM
ROFL if I thought for a minute this thing would handle some I'd prolly be suckin the nipple to ,by now..but I aint done yet with this n/a thing..;)
meengreen 94z
10-08-2004, 08:48 PM
Clyde Moore
ET: 10.66@128
383 LT1
Stock head castings
Turbo 350
Stock suspension
David
Ok, I added a seperate list for Naturally Aspirated cars. If someone wants to list other record holders, such as fastest cam only, fastest heads/cam, fastest bolt on car, etc., Ill post them as well. I know most of these holders by screenname but dont have all the information needed.
Injuneer
10-09-2004, 01:22 PM
You might want to try a "search".... this topic ("fastest lists") comes up about once a year for the last 3 years or so, and there are already several of these lists in existance. I know we put Jonh McMullin's 25th T/A on there, running (if I recall correctly) 9.4@150MPH when he won the second "Fastest Stock Suspension F-Body" event at E'town in 2001. The first event was won by a 3rd Gen, running a nitroused LT1 in the low to mid-9's..... Tony ???? - can't remember his name (fame is fleeting.... :) )
Z8'S
10-09-2004, 02:32 PM
the first winner was Dante with a flying 3rd gen dont recall the et's
Pro Stock John
10-11-2004, 04:38 PM
Madman/Ducote Formula - 9.14? 2000 or 2001 at ETown? Weren't we there Chris or did he run that a few weeks before?
Madman/Castro Z/28 - 9.5 ~ 2000?
George Welter, 93 Pace Car Z/28, first supercharged LT1 in the 10's, circa 1998? Where is that car now?
Jay Billingsley, 93 Z/28, 9.29 or so in 2002? Also went 10.8 n/a.
DaveZLT1
10-13-2004, 08:07 PM
Pro Stock John,
That's what I posted. Ralph Olivarez at AF1M ran a 9.56 @ 141mph in Dallas Castro's old Z28 a couple of years ago when the new owner barely bought if off Castro. For some reason, it was not listed?????????
Nixie_95
10-13-2004, 09:06 PM
is there a fastest for stock lt1 ?
FASTFATBOY
10-14-2004, 12:17 AM
Your car is not stock so why do you ask?
This thread is for the ALL OUT FASTEST LT1's
David
neil350
10-14-2004, 02:51 PM
Soon Rick at HPE will have the fastest LT1 :) I saw the car, it runs now :)
taner
10-14-2004, 04:39 PM
yeah but can he fil it up and go for a 250 miles highway trip? :P
meengreen 94z
10-14-2004, 06:47 PM
No...lol...from what I heard he expects the block to last 3-4 passes at full boost(91.5mm turbo). He'll have quite a few shakedown passes before that though.
meengreen 94z
10-14-2004, 06:53 PM
Ok I added a few names, if anyone can give me some of their missing information it would be appreciated. :)
mike 1978
10-14-2004, 10:06 PM
nice info page.
As for bolt on's, if nitrous counts as a bolt on.
Andy Katzelis
94 Firebird
ALL STOCK LT-1 intake to Y pipe..never been touched (117K miles) , stock suspension, on nitrous and propane
turbo 350 3200 stall
stock rear 373 gear
11.003 @120.56..1.50 60'
2K worth of add ons, still has a factory equiptment. A/C, PS, PB, ETC.
meengreen 94z
10-15-2004, 11:58 AM
nice info page.
Andy Katzelis
94 Firebird
stock rear 373 gear
No, sorry. Bolt ons refers to no power adders.
96LT14u2Nv
10-15-2004, 02:14 PM
dave smith
1995 trans am
10.76@131mph
NATURALLY ASPIRATED
www.lt1dave.com
meengreen 94z
10-15-2004, 08:40 PM
dave smith
1995 trans am
10.76@131mph
NATURALLY ASPIRATED
www.lt1dave.com
Got it
taner
10-15-2004, 10:43 PM
didn't midgame go 10.4 in his all motor 6 speed?
FASTFATBOY
10-15-2004, 11:52 PM
9.70 all motor if memory serves, he makes 570 to the tire on motor.
David
amean94ta
10-16-2004, 06:22 AM
keep this thread going i hope to be in the high 9's this spring my motor is very similer to taners.
p.s hey taner almost time to put it in storage you doing anything this winter?
Joes94TA
10-16-2004, 03:11 PM
Next spring will be very interesting..if not sooner ;)
Nixie_95
10-16-2004, 03:16 PM
David
I was just wondering cuz i have heard a pretty wide variation of times. any thing from 14.5-13.5.
meengreen 94z
10-16-2004, 04:53 PM
I put his name on the list , but I need more information(exact time, mph, setup, etc.)
amean94ta
10-16-2004, 04:59 PM
well joe i am not gonna be the fastest lt1( mid 9's at my best) but i would like to come see ya go down the track sometime where do you useally race at?
FASTFATBOY
10-16-2004, 06:29 PM
I have never heard of a SHOWROOM STOCK LT1 running 13.5, have heard of six speeds running 13.99 in very good air.
David
taner
10-16-2004, 06:41 PM
some head work, and maybe a cam swap. i will base it on flow #'s. other than that....hmmmm no! :) oh and if i can find a spare center section with a spool and toss in some 4.71 gears :) for all motor application.
meengreen 94z
10-17-2004, 01:53 PM
David
I know SLP quoted their LT1 firehawk as a 13.5 car. I've heard of people running 13.7's bone stock.
chevyguy3
10-18-2004, 10:47 PM
<- Darren Nichols
the times you have listed for me are from my 95 Formula that had a 396 with nitrous, not my 94 z28 that you have listed. on motor the firebird went 10.46 @ 128. solid roller 396 with LT4 heads and TH400
chevyguy3
10-18-2004, 10:52 PM
also if you decide to do a heads/cam list, back when i had a stock shortblock and 6 speed in the car it went 11.34 @ 121 on motor and 10.54 @ 132 on the bottle
amean94ta
10-18-2004, 10:53 PM
if you may what cam where you using? what n20 shot? what did the heads flow
chevyguy3
10-18-2004, 10:55 PM
on the 396 or on the stock shortblock?
amean94ta
10-18-2004, 11:07 PM
the 396 sorry i should have said
chevyguy3
10-18-2004, 11:16 PM
cam was a 254/259, .664/.656, 112LSA
200hp shot, but very tuned down for a ways out of the hole since i had bumper standing problems
heads actually werent hogged out much, had much smaller runner ports than all the "Stage 3" LT4 heads i have seen. 2.00/1.60 valves, 279cfm max intake flow on a bench that supposedly reads low (dont really know if thats the case or not). they seemed to work well on all 3 combos they had been on though (same heads that were on my stock shortblock combo, and same heads George Baxter ran before switching to his Canfield setup)
amean94ta
10-19-2004, 03:38 AM
thats great i have the cc306 but before you start laughing i have a very great set of heads and was told not to go so high with the lift cause the larger valves wont need it with my heads flowing 270's at .600 and 230's on the exhaust(manley race flows 2.02/1.60 ) if it dont work i just switch the cam no big deal
amean94ta
10-19-2004, 03:46 AM
what cam you got taner? when you switch wanna trade? lol
taner
10-19-2004, 07:25 AM
lmao!! good one, i'd give up my first born before divulging that information ;) just kidding. all i will say is it has well over 200 duration, and well over 600 lift :D
ford
10-19-2004, 01:36 PM
LMAO learn where the edit/delete button is :Owned:
Cody
10-19-2004, 03:31 PM
What classifies as an LT1? I am still running my LT1 block, AFR LT4 heads Accel super ram intake for lt1.
meengreen 94z
10-19-2004, 08:58 PM
<- Darren Nichols
Ok, I fixed it and put you on the NA list. :) If I expand the other lists I'll put your name there as well.
meengreen 94z
10-19-2004, 08:59 PM
I'll put your name on as long as you still have an LT1 block and your time can be confirmed.
Cody
10-20-2004, 09:04 AM
I'll have to wait till spring for a time slip, but we are going to be tuning the engine on a engine Dyno in the next 2 weeks and we are sure it will be around 1400 FWHP. although the times here in the Rocky mountain region wont be in the 8's I should get into the mid 9's
madman69
10-20-2004, 10:47 AM
The stock internal record at 10.86 is Craig Millers 96 T/A. The motor was totally stock valve covers had never been off. The car had hooker longtubes and a mufflex exhaust. Moroso cold air, and a 52mm t/b. I put a th400 with brake and a 9" in it. It had stock interior and all the accessories. The car had a 150 dry NOS kit on it. The car went a 1.38 60ft and was deadly consistent. The key was the suspension.
Frans96SS
10-20-2004, 01:43 PM
i hope to be on that list soon and hopefully at the top :D
meengreen 94z
10-20-2004, 02:25 PM
Well, Im in Laramie right now going to Wyotech, so were not too far away. If you need an extra hand, I have no probelm helping out.
meengreen 94z
10-20-2004, 02:27 PM
Ok, I fixed it. You wouldnt happen to remember the date(approx.) you took the record of fastest LT1 and the trap speed on your formula's 9.14 pass?
FASTFATBOY
10-20-2004, 02:42 PM
Hopefully by next summer I will be high on the all motor list. Goal= 10's in a 3600# Z28 with all the factory comfort options intact....on a Drag Radial with 23* heads, all motor, yeh bubba it ain't yo ordinary LT1.
Oh yeh Add Mike Barnes to the list
He in a full weight Z
He wont tell what size engine, well he says a 355
But he runs mid 11's on motor and 10's on artificial atmosphere, car gotta be 3600#'s He is on this board Silverzz28 I think, e mail him and find out.
David
meengreen 94z
10-20-2004, 06:28 PM
For now atleast Im keeping the list of NA cars 10.99 and under. :)
Frans96SS
10-20-2004, 10:13 PM
im hoping to be in the top 3 n/a and hopefully the number 1 for power adder
Z8'S
10-20-2004, 10:19 PM
Wanna race? :D
Stepping up the program quite a bit at the moment, should shatter my old times .Then the car goes up for sale.
Cody
10-21-2004, 10:27 AM
I'm in Cheyenne
kamba93lt1
10-21-2004, 12:45 PM
Well I saw 10.99 was the top. Well I just fit into the NA list.
Best is a 10.983 @ 120.93
Best 60' 1.442
Best 1/8: 6.950 @ 98.23
Best 1/8 mph: 99.90
Best 1/4 mph: 122.77
Just a NA 355 LT1.
Next year I will be much much further up the list.
Ken
Tekprodave
10-21-2004, 01:12 PM
You know we could add another category for fastest untouched LT1. And that would be me. :D Or I could slap on some RR's and take down SAR2K. I don't think Steve would like that but it would be all too easy. :cool:
Frans96SS
10-21-2004, 01:21 PM
Wanna race? :D
sure ill run u but my car wont be done for like at least another 6 monthes or so..... i should be getting ready to dyno it in about 3 weeks or so ..thas engine dyno not chassis
meengreen 94z
10-21-2004, 02:43 PM
Best 60' 1.442
Best 1/8 mph: 99.90
Just a NA 355 LT1.
Ken
Ok I added your name, what year and model is your car?
meengreen 94z
10-21-2004, 02:46 PM
Wanna race? :D
Just wondering, what was your mph and 60ft time on the 8.93 pass?
Stinks that you have to sell it, but let me know when you better your record. :)
kamba93lt1
10-21-2004, 03:27 PM
oh yeah. Sorry.
1993 Z28
TEA LT1 heads, hyd. cam. turbo 400 w/ brake, KTRE 12-bolt w/ 4.56, 28x9.0 slick.
Ken Kamba
Z8'S
10-21-2004, 05:12 PM
60ft 1.341
1/8 5.750 @123.96
1/4 8.928 @152.61
Dont have to sell it ,just tired of all the time it takes .
madman69
10-21-2004, 05:25 PM
We ran the 9.18 pass at Englishtown in October of 2001 I believe. It was against Baxter.
amean94ta
10-21-2004, 05:50 PM
2-3 years you will buy a new car and start over. its like crack nobody walks away.
Frans96SS
10-21-2004, 06:08 PM
how fast are u thinking ur gonna go, and what heads are u runing now afr rr's?
meengreen 94z
10-21-2004, 06:35 PM
60ft 1.341
1/8 5.750 @123.96
1/4 8.928 @152.61
Well I wouldn't sell it too soon. You may finally have some competition for the record(Bigrick, Frans96ss).
Z8'S
10-21-2004, 07:18 PM
Most people know what my combination is, Whats yours may I ask? :)
Tekprodave
10-21-2004, 07:48 PM
:confused: What's up guys? No love for the Tekpro? I guess maybe I should prove my point by going for these:
FASTEST BOLTON LT1 (just need a set of RR's and valve springs, heck I could prolly do it with just a PCM tune) :D
FASTEST INTERNALLY STOCK LT1 (a 150 shot ought to do it)
FASTEST CAM ONLY LT1 (easy just get a bigger cam if necessary)
FASTEST HEADS/CAM LT1 (Challenging but doable)
FASTEST STOCK BOTTOM END LT1 (more challenging but great if I could hit a 9 without building the motor) :metal:
meengreen 94z
10-21-2004, 07:56 PM
Its a VERY impressive time, Im not taking away from your accomplishment by not adding your name to the list. But seeing how rockerarms have been ruled a bolton, I dont really see a point in creating an NA untouched LT1 section when the bolton listing is pretty much the same thing minus one mod. All you have to do is beat one of those times and I'll put you on the list.
Tekprodave
10-21-2004, 07:59 PM
Sweet!! :bow:
Frans96SS
10-21-2004, 08:59 PM
well i really dont know urs but mine a 396 callies crank, oliver rods, custom je pistons. afr rr heads, brodix intake, and how ever much nitrous it takes to beat ur record or u haha
Z8'S
10-21-2004, 09:09 PM
And you have run what so far? Thought so. Theres nothing to it .Good luck in your quest (serious)just dont be to cocky please. ;)
taner
10-21-2004, 09:24 PM
i love how easy it is for people to say they are going to be #1, etc....
sorry, it isn't that easy! just my 2 cents. good luck to those with their aspirations. i have been fortunate enuff to trample my goals and beat them with a hammer! always looking to better my p.b.
Frans96SS
10-21-2004, 10:07 PM
i never said i WAS goin to be the fastest i said i hope but i know my motor will make a very good amount of power. and i will have very good chassis to back it up i never said iw ill be the fastest but i think i will deff be a top contender
YTRY50
10-21-2004, 10:30 PM
You forgot about Dave Odehnal, black 93Z with QTRZ28 on the plates.
10.15et, 134mph, w/1.37 60ftw/BEST 1.30 60FT, N/A lt1, with factory heads and intake.
http://www.thundershootout.com/photos/2003/Saturday043.jpg
Joes94TA
10-22-2004, 12:14 AM
might want to add I was the first n/a lt1 in the 9's ..:)
also I have the 60 ft record on stock suspension so far 1.264 thanks to madman :) brian had it with a 1.265 and basically still does since hes the reason I cut the 60 ft I did..
Also want to say congrats to all on the list so far...anyone on that list knows it isnt that easy to achieve some of those times.....and anybody that thinks it is.....they'll find out first time they hit the track.....
my goals has also been surpassed but I have another and hopefully come spring if not earlier, I'll surpass that one as well...:)
rskrause
10-22-2004, 06:56 AM
I probably don't belong on the list, but FWIW I am pretty proud of my times in that my car is is full weight (~3,850lbs), runs full emissions equipment, and has a "road race" type suspension with a best time as follows on 100 octane unleaded:
60': 1.55
1/8: 6.55
mph: 110.52
1/4: 10.06
mph: 141.15
Rich
taner
10-22-2004, 07:25 AM
60': 1.55
1/8: 6.55
mph: 110.52
1/4: 10.06
mph: 141.15
Rich
why the hell wouldn't you belong on the list :) nice times!
Nostang 96z
10-22-2004, 10:06 AM
I prob don't belong on the list either but I will post my times anyway cause I am proud of my stock crank, 2 bolt main 355 with common mods. I also have a high raceweight of 3650lbs and my car is a street car (not totally gutted just !AC, !ps, !pb).
150 shot footbrake off idle launch on the spray
1.437 60ft
6.565 @103.79 1/8
10.354@129.34 1/4
only 200 shot shakedown pass---footbrake NA launch hit the spray right at the 60ft
1.592
6.595@107 1/8
10.27@133.24 1/4
Should be in the 9's once I play with the timing and launch harder (1.3 60ft should be easy of the t-brake) then maybe I can make the list.
Matt
rskrause
10-22-2004, 11:31 AM
Well, it took "dual power adders" to do it!
Rich
N20Dave
10-22-2004, 12:01 PM
I think everybody deserves a round of applause for what they have accomplished whether on the list or not.
With the new motor I'll be making enough power to get on the list.....
Whether or not I can get it down the track to get the slip to actually make the list is another story.
meengreen 94z
10-22-2004, 12:03 PM
I added him to the list, You wouldnt happen to know the size of his engine or other specs?
meengreen 94z
10-22-2004, 12:05 PM
When did you run that first 9 sec pass and what was the E/T?
meengreen 94z
10-22-2004, 12:06 PM
Rich
I'll expand the list to 10.5 with a power adder . Anyone who wants their name added just post up your name, time, and setup.
Cody
10-22-2004, 12:09 PM
I'm curious, At what altitude are the fastest LT1 cars running? Between Denver and Vegas can be as much as 5 tenths of a second difference so I think that where they run would be a big issue.
N20Dave
10-22-2004, 01:01 PM
I'll expand the list to 10.5 with a power adder and 11.5 NA tonight. Anyone who wants their name added just post up your name, time, and setup.
N20Dave
60'.....1.55
660'....6.70
mph....103
1/4.....10.47
mph....131
396, CNCLT1's. 225shot, T56
JZ 97 SS 1500
10-22-2004, 03:43 PM
This is a customer of mine.
60ft- 1.87
1/8th- 7.41@102.40
1/4- 11.31@126.54
The car is a 95 Camaro Z28, 6spd, stock gears, bone stock motor except for 1.6RR's and addition of suspension components. The car is using the PTK Gen 1 street kit with PT66 p-trim .96 A/R, 2.5" downpipe. Car was dyno tuned at 8psi on 93 pump gas and tap water in the intercooler and made 479rwhp/555rwtq. I have sent him larger head unit and he will be running ice in the IC and ~10psi. Should be a competitive #.
Jose
flyin_hawaiin
10-22-2004, 04:21 PM
Hey Z8's... ill run you with my LT1 and smoke your ass....
meengreen 94z
10-22-2004, 04:46 PM
Just wondering, what is your setup/ et's?
Z8'S
10-22-2004, 05:06 PM
He's my illegitamate son that drives my car.You're grounded.
He also has an 8.5's Renegade Mustang :p
flyin_hawaiin
10-22-2004, 05:08 PM
im not related to you... you are old with white hair..
i have dark hair..
meengreen 94z
10-22-2004, 06:32 PM
With an LT1 in it? :confused:
taner
10-22-2004, 07:04 PM
I think the sig is an inside joke! lmao!!
Z8'S
10-22-2004, 07:37 PM
You can add Jim Moran a.k.a INTMD8
He ran his car at a track rental today
9.809 @149 mph
LT1 twin turbo 6 speed about 3800lbs.
Way to represent Jim !!! :bow:
meengreen 94z
10-22-2004, 07:48 PM
Judging by the dyno in his sig I figured he was referring to INTMD8
Im guessing he owns an LT1 as well as his mustang looking at his reply:
meengreen 94z
10-22-2004, 07:52 PM
9.809 @149 mph
Got it :)
taner
10-22-2004, 11:08 PM
9.80 @ 149......damn that is awesome! amazing mph!!!!! :bow:
how cool is that the 2 fastest 6 speeds (for now) are LT1's! damn straight, way to represent. got video? would love to see that thing pull like crazy on the top end!
meangreenz,
i think it is time to separate the 6 speed cars...whatcha think, after all you are generous enough to maintain this list.
FASTFATBOY
10-23-2004, 12:42 AM
60ft- 1.87
1/8th- 7.41@102.40
1/4- 11.31@126.54
Jose
Jose, your 97 SS made 460 rwhp BEFORE the turbo?? Out of a AFR 195 headed, stock intake 383 with 8.5 to 1 compression? Please elaborate.
David
YTRY50
10-23-2004, 02:16 AM
I dont know much about the engine, As he keeps quiet about it. I do know from looking at the car it is full factory interior (even back seats) The car looks completely stock other than a cage.
Unfortunatly he had a mishap at Gateway a few months back, but the car will be back on the street come spring time.
madman69
10-23-2004, 09:29 AM
I am wondering if this list has any verification process on these times??? I see some questionable cars on here.
meengreen 94z
10-23-2004, 01:23 PM
Which cars are you talking about(Ill look into them if you can help give me an idea)? I was hoping people would be truthful, and that readers of the list would help weed out wrong numbers, cars, people etc. I chose this process due to most official lists leaving out several names. Usually due to the fact that those people never look at that website to post/verify their times.
JZ 97 SS 1500
10-23-2004, 01:33 PM
FASTFATBOY, yeah, my car was a 383, with 10.5cr, CC306, LT4 intake, 195 AFR heads that were fully ported...etc..etc. The car I posted about is not my car, its a customers car though, with a stock motor and PTK turbo kit. My car now has a custom turbo cam, 8.5CR and its a fully forged bottom end. I have not run mine yet, nor has it been on the dyno....yet.
Jose
rskrause
10-23-2004, 01:40 PM
Madman: care to elaborate? -If you, for example, didn't have credibility someone might look at your times and say "oh ho, a BS'er!". Some of these times are damn fast, for sure. Just wondering which ones make you suspicious?
Rich
FASTFATBOY
10-23-2004, 04:40 PM
Jose
On your site it says 460 rwhp BEFORE the turbo for YOUR car.....that is what I am asking about.
Heres whats on the site:
Performance
Normally aspirated:
60ft 1.51
1/8th 7.27@97.46
Dyno ~460rwhp/420rwtq
With Turbo:
Coming soon
madman69
10-23-2004, 07:01 PM
All of my cars AND the cars that claim my suspension can be proven. All the times posted have been in actual competition or can be verified by a handful of witnesses. Somebody posting their friends, buddys, uncle had a car type deal could be bogus. The only one I see as NOT PROVEN is Vince AKA Spray the Way.
rskrause
10-23-2004, 09:40 PM
I wasn't doubting you at all, you DO have credibility. Just saying that none of the times are "official".
Rich
SAR2K
10-23-2004, 10:45 PM
...I could slap on some RR's and take down SAR2K. I don't think Steve would like that but it would be all too easy. :cool:
Do it!!! :D Actually Dave I set that record almost two years ago... it's LONG overdue to fall in my book. So by all means please break the record... then I'll have a reason to go back to a Bolt-On motor. :death: :p
Hey does my current stock bottomend time with factory LT1 castings get me anything???
Steve...
taner
10-24-2004, 01:36 AM
Steve...
it'll get you an Ice Cold Canadian! :) :D
SAR2K
10-24-2004, 11:26 AM
:D That'll work Taner!!! I assume I can expect it in about 2 weeks right, LOL! :p
JucinGTA
10-24-2004, 12:45 PM
Any chance I can get added to the N20 list.
I went 10.44s @129 with a 200 shot/fogger in 80 something degree weather
Comps Nitrous Cam
Stock Shortblock
INTMD8
10-24-2004, 10:43 PM
9.809 @149 mph
Thanks Chris :)
BTW, I think a pair of GT70's would fit nicely under your hood. :eek:
Tekprodave
10-25-2004, 11:25 AM
Steve...
LMAO!! :lol: Steve, you are the coolest. :bow:
I've gotta get a roll cage put in so it may be a while. :cry:
JZ 97 SS 1500
10-26-2004, 02:15 PM
New time from my customer.... details below
Mods
Stock motor, with 1.6RR's
6spd with spec clutch
Gen 1 PTK turbo kit with 2.5" downpipe
Master Power T70 with PTE .96 A/R
Ice water in Intercooler
10psi and 93 Octane
315 Nitto DR's
first pass:
60ft- 1.84
1/8th-7.25@104.49
1/4- 11.03@130.47
2nd pass, and needless to say, the pistons went at half track, but the aborted pass was a 10 second run nonetheless...well would have been….hehe
60ft- 1.78
1/8th- 7.18@105.12
1/4 -16.98@57
Jose
WIKIDTA
10-26-2004, 03:12 PM
Thanks Guys :) :D
Ya, those times were a few years ago. I've upgraded a few things since then..jessel rockers, F.A.S.T.sequencial Wideband engine managment system and never had a chance to get back to the track.
Unfortunally I doubt I'll be racing the car again. :(
Agostino Racing really screwed me over for the past 2 years. While my car was up there for the installation of the new FAST system Wade "dickhead" decided to place my rotating assembly into another customers car(called Stealing here in the States) and charged him for new parts and decided to jump ship leaving me screwed without a bottom half. Nick tried to compensate, but basically I got screwed over since he couldn't do anything to replace my loss for the past year dispite all the BS promises. :mad:
I gave them every chance and still they couldn't keep good on any promises. I've been fighting with them for months and finally just got my car back without my motor completed before I would lose anymore stuff if they close up shop for good. I got a new block, new callis crank in the box...and all the parts for my motor except rods, cam, and pistons.
:eek: :eek: :eek:
The car is now FORSALE if anyone wants to finish this. Price is unbeliveably low, but I'm out of racing. :eek:
$12,000 or best takes everything I own for the car. I'm just basically giving it away for that price. I just don't have the time anymore to finish this and continue racing.
Check out my web page if your looking for a 9 sec car that needs $3k in parts to be back up and running.
meengreen 94z
10-26-2004, 04:48 PM
Thanks Guys :) :D
:eek: :eek: :eek:
Man that really stinks. I've heard quite a few story's about Agostino. Hate to see you get rid the car when you had some nice plans for it, but I can understand your feeling.
JZ 97 SS 1500
10-28-2004, 11:10 AM
Anyone know what the fastest stock motor mph is??
Jose
meengreen 94z
11-07-2004, 01:32 PM
I updated the list for Ricks record. If anyone else wants their name added let me know.
wot-z28
11-07-2004, 05:39 PM
Maybe you could include me hehehe, im 16 and running in the 12's. Maybe I could be the youngest-quickest lt1 driver. Sorry to rain on your guy's parade im just way exuberant on my new times from the trck. bubye.
taner
11-09-2004, 12:00 AM
just back from thunder shootout! :)
9.44 @ 146.18 on a 1.355 60' n2o
10.744 @ 127.04 NO BOTTLE!!!!!! All motor. i believe that nets me the fastest n/a LT1 6 speed with lt intake. booooyaaaa! that was bogging on a 1.49 60' :( could have launched harder , no more opportunities as i switched to bottle mode on sunday! :)
just wait till next year! :)
meengreen 94z
11-09-2004, 02:13 PM
Ok I fixed it :)
Too bad I didnt get to make it out this year, there were some great results. Maybe next year.
taner
11-09-2004, 06:05 PM
thanks! too bad you couldn't make it out, not too far of a drive for you!
meengreen 94z
11-09-2004, 07:17 PM
No problem. :) Yeah I would have shown up if I was still in Houston. But right now Im in Laramie, which would have been almost as far a drive as for you(almost).
amean94ta
11-13-2004, 03:47 PM
I noticed you dont have randy brown on the list he is from hillsborough, nc 1994 formula 395 ci nos 150 dry kit ported lt1 heads 2.00/ 1.60 54cc 1.52 rr 11.3:1 comp lunati 600/600 250/259 na 453 rwhp @5,700 450tq@4,700 n20 60h rwhp @ 6,000 700 ft lbs @ 3,900 built by jeff creech at automasters durham, nc
meengreen 94z
11-13-2004, 03:53 PM
What were his times? :)
95z6spd
11-13-2004, 06:45 PM
You should have a spot for fastest naturally aspirated totally stock internal LT1 6spd...I'd be in second.. only by .05 seconds ;)
amean94ta
11-14-2004, 12:29 AM
HA HA i am stupid lol :D 10.547 at 131.48 with a 1.48 60ft
also it weigh's 3,750 lbs full leather interior with ac 128k on the car and 4k street miles a year. was clocked by the east coast timing association at 168.8 mph
MBonZ28
11-14-2004, 02:19 PM
man Darren that really sucks. I am sorry to hear that. for those that dont know the car that is one hell of a deal. you should have no problem selling it. If I wasnt in the middle of a project myself I would be all over that
meengreen 94z
11-21-2004, 04:32 PM
Hey guys I added a few names, but had to take down the 6-speed list due the overall list becoming too large(10,000 character limit). To make up for this I added 6-speed tags to distinguish those who stuck with the T-56.
If anyone wants their name added let me know.
Mike Comp T/A #57
11-24-2004, 07:22 PM
Add my name to the list. Stock internal LT1 with 150 NOS.
95Bird
11-24-2004, 07:38 PM
you forgot to put 6 speed by my name..lol. :p
amean94ta
11-24-2004, 10:25 PM
we will need a vid for that a stock ta with a 150 dry kit goes 10.89? :confused:
meengreen 94z
11-27-2004, 02:49 PM
fixed it :D
meengreen 94z
11-27-2004, 02:51 PM
It's definitely hauling for the mods, but Craig Miller ran a 10.86 at 120 with just boltons and a 150 shot as well.
Mike Comp T/A #57
11-27-2004, 07:31 PM
It's definitely hauling for the mods.
Thanks!
T/A lt1
11-30-2004, 02:16 PM
You could put me at the bottom of the Naturally aspirated list. Only second time out with this setup. 11.24@120.8mph 355" LT1 with ported LT1 heads, CC306 hydraulic roller, forged pistons,TH350/3800converter and stock 10bolt with 3.42's. I am working my way to the 10.90 club with this same setup. My car has also been 10.84@126.8mph on the stock shortblock with heads/cam and a 150shot so it should be somewhere on the list.
meengreen 94z
11-30-2004, 07:37 PM
Your cars definitely fast, but unfortunately due to a text limit(10,000 characters) on this website I have to keep the lists at 10.49 and under for the main list and 10.99 and under for the N/A list(Ive had to delete stuff to fit other peoples names). Im thinking about at somepoint making a seperate site for this list, and then Ill add anyones name. :)
T/A lt1
12-01-2004, 10:02 PM
Well i'll just have to go 10.98N/A and 9.90's on the spray which should happen shortly. Later Clint
amean94ta
12-01-2004, 10:33 PM
you cant thats what i am going to run :D
tubby
12-02-2004, 08:46 PM
**UPDATE**
Ric Fleck (TUBBY)
FLEX RAcing
went 9.490 @ 141.6 last night at darlington SC
60' was 1.37
procharged/NOS 1997 t/a
meengreen 94z
12-03-2004, 08:29 PM
**UPDATE**
Ric Fleck (TUBBY)
FLEX RAcing
60' was 1.37
fixed it :)
T/A lt1
02-27-2005, 07:41 PM
Well how about now? 10.23@132mph. 355" LT1, LT1 ported heads, CC306, Th350, stock 10bolt with 3.42's and a healthy dose of 175HP NX on a 1.55 60'. LMK I will give you the rest of the details. Clint
meengreen 94z
02-27-2005, 11:30 PM
Ok I added you :)
T/A lt1
02-28-2005, 03:38 PM
Thanks, It also ran 6.51@106.7mph in the 1/8th mile. The car also weighs 3,500lbs, 3" true duals exhaust all the way to the bumper and 3.42 gears. Later Clint
tubby
02-28-2005, 04:28 PM
**UPDATE**
Ric Fleck (TUBBY)
FLEX RAcing
went 9.20 @ 145.9 sat. night 2/26 at SVT day jackson SC
60' was 1.27
meengreen 94z
02-28-2005, 07:28 PM
**UPDATE**
Ric Fleck (TUBBY)
FLEX RAcing
60' was 1.27
Fixed it....nice time by the way :)
Joes94TA
03-01-2005, 08:09 AM
CAM/ HEAD Lt1....figured I'd add James Eddy since he dont post here much..
ported factory lt1 castings and hyd. roller stock bottom end
1.49 60 ft.
7.01@99mph
11.05@120.1
race weight est. around 3500lbs
1st and goal
03-01-2005, 08:42 AM
You can slide me in at #31
10.02 @ 135.71 w/ 1.47 60 ft
383 D-1 19#
Timeslip
http://www.tta89.net/marc/10-02run.jpg
Video
http://www.tta89.net/marc/10zerorun.mpg
Marc Rahn
meengreen 94z
03-01-2005, 08:43 PM
383 D-1 19#
Timeslip
Video
Marc Rahn
I added you to the list :)
Im going to reorganize the list this weekend and seperate it into two lists, Power Adders and Naturally Aspirated. Feel more than welcome to post up your times, I'll add them this weekend.
meengreen 94z
03-01-2005, 08:46 PM
1.49 60 ft.
7.01@99mph
11.05@120.1
Unfortunately Im running out of room(character limit) :( , other wise I'd expand the list to include everyone. Maybe sometime this spring I'll make a seperate website.
PNYKILR
03-02-2005, 03:04 PM
I race at 5,300 elevation. I guess my ? is do corrected times count. Up here this past weekend I went 11.33@122mph on a 1.58 60'. DA was 6,000'. Corrected for Sea Level was 10.41@131mph. All Motor 6 speed car.
398cid
Solid Roller
AFR 210's
Currie 9" with 4.56's
Weight should be 3,400 pound(that's a guess)
Car made SAE 500.4rwhp & 457.1rwtq, uncorrected here made 413rwhp & 376rwtq.
If you don't use corrected times that's cool. I'm just stuck at a mile high that's all.
Neal
LT1Squirrel
03-02-2005, 03:52 PM
shouldnt the marks read quickest?....just a suggestion :cool:
SAR2K
03-09-2005, 01:04 AM
1.49 60 ft.
7.01@99mph
11.05@120.1
Damn you Joe & your LT1 magic, LOL!!! ;) Can I assume Eric had something to do with those heads??? ;) You better cut this crap out!!! You'll scare the LS1 guys off!!! :D
Steve... slow LT1 guy
Joes94TA
03-09-2005, 10:06 PM
Steve lol yeah Eric did them out in his tinshed ...as far as the ls1'ers they havnt seen scared yet..;) even though I been working on a few of those as well...
andy katzelis
03-10-2005, 07:52 AM
I went 11.003 @ 120.59.
Internally stock and externally stock, from the stock paper filter and box to the stock crossover pipe....on a big shot.
95Bird
03-12-2005, 02:33 AM
Please update..set a new best tonight. 10.77 @ 127.65 on a crappy clutch slipping 1.509 355 6 speed with ported factory lt4s.(No AFRs here :p )
Time for a new clutch. I want my low 1.4 60's back
MattSLONOMO
03-13-2005, 11:51 AM
My current best was 10.30 @ 135..this was with a 2.25 60'
on a 300 shot..sideways off the line and sideways in 2nd..no lifting though!
was it fear or anger..?..LOL..
355 ci..4L60E.. stock pcm 4.11 gears
Matt
STROKEDOUT
03-18-2005, 09:07 AM
Can you please ad me...Duke Sullivan
I have a 95 firebird 396 lt4 heads, th350, 4500 stall, went 10.50 @128 with 1.41 60ft N/A
LT1 Bunny
03-23-2005, 07:47 AM
Too bad Mike Moran's motor isnt an LT1. He did very well at the Rock the other week too. 6.29 at 201 I believe. I'm thinking about giving him my LT1 and see what he could do with a little power adder...but then again that takes all the fun out of building your own motor!
JZ 97 SS 1500
03-30-2005, 11:31 AM
My customer just ran his car this past weekend...not the fastest ET in a 6spd like Taner, but I think its a contender for the fastest mph in a 6spd record...
http://forcedinductions.com/images/timeslip.jpg
Details on the car can be found in link below...
http://forcedinductions.com/v-web/bulletin/bb/viewtopic.php?p=335#335
Jose
taner
03-30-2005, 05:59 PM
Jose
:bow: that is killer!!! congratulations, and yes that is the fastest mph yet in a f body with 6 speed!!! :bow: congrats to you and your customer!!!! :cool:
JZ 97 SS 1500
03-30-2005, 06:04 PM
Thanks, but he is still a long way off from a 9.44 you put down. I believe Jim ran 9.68 in his turbo car as well and 6spd. So guess he is only 3rd fastest ET. Guess mph will have to do. Doubt my customer will ever get close to 1.4 60ft's...lol.
Jose
taner
03-30-2005, 07:46 PM
Jose
yes maybe not quickest, but mph wise he has us all hell got me by 10 mph!!
but the race season is about to begin up here :D
jamilz28
03-30-2005, 09:31 PM
i have the fastest lt1 in the world 2sec in the 1/4 mile ( but thats only before i wake up )
AdioSS
03-30-2005, 10:36 PM
Jose
that MPH is good for mid 8s if it can hook up. They are definitely making the power for it! :D :eek:
What tires were they running?
JZ 97 SS 1500
03-30-2005, 10:39 PM
They are 28" ET's. It was soft launching in hopes the tranny would last at least a few passes. It did last 2 full passes.
N20Dave
04-01-2005, 01:26 AM
Jose
:eek:
YTRY50
04-02-2005, 12:15 AM
That time slip is from 1978! :lol:
JZ 97 SS 1500
04-04-2005, 01:53 PM
hehe, yeah everyone seems to laugh at the 1978....lol. Guess the track forgot to do the Y2K patch on the OS...hehe.
Jose
T/A lt1
04-04-2005, 07:06 PM
Please update my times. 200HP NX leaving soft.
1.53 60'
6.50@105mph 1/8th
10.17@133.6mph 1/4mile on ET street Radials! Thanks Later Clint.
meengreen 94z
05-07-2005, 11:38 PM
The list is revived! Sorry guys I've been busy with a new job combined with no internet at home. I fixed the list and divided it into two sections: power adders(10.49 and under) and Naturally Aspirated(10.99 and under). Feel free to post your times if your name should be somewhere on the list.
meengreen 94z
05-07-2005, 11:40 PM
Jose
I added the car to the list, what name should I put the car under?
JZ 97 SS 1500
05-08-2005, 01:00 AM
The owner's name is Jeremy Sanchez
Jose
meengreen 94z
05-08-2005, 01:17 AM
Jose
got it
taner
05-08-2005, 09:22 PM
i just wanted to update my n/a personal best
10.54 @ 129.28 mph, on a 1.497 60'
i had hoped to have a new n2o number but sdrove through the ring and pinion when i dead hooked the car on my first n2o pass last weekend, oh well, gonna wait till first weekend of june to try it again once our new shop is open.
Joes94TA
05-08-2005, 09:26 PM
Congrats Taner,,,I should be up and running in about a week ....:)
also gimme a call tommorow I have something here for you..;)
taner
05-08-2005, 09:47 PM
thanks! i will actually send steve your contact info, he will get in touch with you :) he is eagerly awaiting this. damn i still have to finish up his intake! :cry: lately the only time i am not working is when i am sleeping.
95Bird
05-08-2005, 11:35 PM
HEY!!!!! What are you guys scheming without me???? I don't like being left out of the loop :mad:
Sorry to hear about your bad luck tanner..I should be trying out my new 10.5 Ws and tried some more stuff to try and fix this studder problem..we will see. I did run 128 mph last weekend on a 1.78 60'(huge bog..left way to low trying out the new clutch), I was still having to short shift and went through the lights spitting and missin. :cry:
meengreen 94z
05-09-2005, 10:57 PM
Got it :)
95z6spd
05-12-2005, 11:33 PM
Can you make a spot for the fastest Stock Internal N/A LT1 class. I am going for the record and I am currently in 2nd place by .05 seconds. I'm having my Stage 3 clutch installed on the 24th and then the record will be mine soon after that :bow: Then I might join roadtrip and go battle it out for the 11's in the bolt on class. that would be bad ass :cool:
Tekprodave
05-13-2005, 01:43 PM
I asked for this a while back but the list is already too long so my request was denied. I'm not sure what you are shooting for but mine is the time to beat. (12.042)
95z6spd
05-13-2005, 02:56 PM
I'm shooting for the SI NA 6spd LT! record which is 12.48....As far as the lis being too long?? I dont follow. a list can be as long as some one wants to make it. Top 5 or 10 should be fine. The list for any of the categories COULD be long....its just how many do you want to/need to list...
meengreen 94z
05-20-2005, 09:56 PM
Camaroz28.com limits single posts to 10,000 characters. Im nearly out of room on that first post and have had to made changes to make things fit. When I get the time maybe Ill create a new list and seperate it into several posts.
Tekprodave
08-04-2005, 11:25 AM
LJ's times need to be updated:
http://para.noid.org/~lj/
He hit 9.47 @ 148mph :bow:
Victory Racing
08-05-2005, 03:26 AM
Man what a great list.
Brought back some old memories and some good and some bad;)
meengreen 94z
08-05-2005, 10:17 PM
Got it
meengreen 94z
08-05-2005, 10:18 PM
amean94ta
10-30-2005, 01:19 PM
ttt lets get this baby updated
95Bird
10-31-2005, 10:40 PM
Updated times in my sig... :p
taner
11-01-2005, 07:14 AM
updated times in sig as well. :)
Joes94TA
11-01-2005, 08:35 AM
update for me : 9.34@142.66
new best 60 ft. 1.245
also:
cam /head ( James Eddy) stock ported heads and intake ,hyd.
10.88@122 on drag radials
andy katzelis
11-01-2005, 08:40 AM
Internally stock LT1, 3rd quickest?
meengreen 94z
11-05-2005, 12:21 AM
Sorry guys it took me a while to respond, but I fixed all the times. :)
meengreen 94z
11-05-2005, 12:25 AM
Your time is quite a feat:). But for the time being I have to limit the list due to size constraints. Maybe one day if I have the time and theres still interest I'll create a website specifically for the records.
meengreen 94z
11-05-2005, 12:27 AM
also:
I went ahead and gave him the H/C record for the time being. I could never get any exact info on Steve Quinns H/C record, but if anyone knows let me know.
Quickshotkimber
11-05-2005, 07:04 PM
Thanks Joe and Meangreen, here is the pass info,
1.51 60ft :(
6.90 1/8 @ 99.08
10.88 @ 122.81
1500 ft DA
3400 race weight
Thanks again :D
meengreen 94z
11-05-2005, 07:16 PM
1.51 60ft :(
6.90 1/8 @ 99.08
10.88 @ 122.81
1500 ft DA
3400 race weight
Thanks again :D
Fixed it :)
Lisa33
11-06-2005, 10:33 PM
383 F1 17psi FMIC ported TFS heads 4l80e 2700vig 3.42 rear 1.69 6,68 110 10,21 141.5
Ake Eliasson
Sweden
CMSDave
11-07-2005, 08:09 PM
You can change Quickest Impala SS to Combination Motorsports/Voss Boreta.
383 LT1
F1R Procharger
TH400
3000 Stall
3.50 Rear
4250# raceweight
96 Impala SS: 6.273 @ 109.64 1/8, 9.860 @ 136.61 1.395 60'
Timeslip is from Nov. 4th, 2005
Thanks.
AdioSS
11-08-2005, 08:33 PM
Dave, this is the list for the FASTEST LT1s, not the quickest :p JPG's 140mph trap speed is definitely FASTER, but his 9.98 isn't as QUICK :D
Just messin' with you guys!
meangreen, I'm wondering if there is anyway that you can have both impalas on the list since it is one heck of an accomplishment to be in the 9s with an LT1 powered 4000# boat.
Shon Herron
11-13-2005, 12:51 PM
Been waiting a while to do this but I can now post it, please put SAR2K and Roadtrip 2nd and 3rd in the Bolt on LT1 race
Shon Herron/Herron Performance
Fastest/Quickest Bolt On LT1
A4 and M6 Record
60' 1.59
1/8 7.56@89.8
1/4 11.909@113.1
backed up with a
60' 1.624 Spinning
1/8 7.57@90.27
1/4 11.897@113.6
RW is 3090 and DA was -508'
FASTEST BOLTON LT1
SAR2K-Jan '03-AUTO RECORD
11.94 @ 111.5
60': 1.53 60'
3510 race weight
Brady Matysek "Roadtrip120"-6SPD RECORD
1994 Z-28 M6 -Every Bolt-on, 327rwhp 349rwtq
1/4: 12.295 @ 112.01
1/8: 7.905 @ 88.51
60': 1.76
Tekprodave
11-14-2005, 11:36 AM
Hey nice job!! It sure helps to have the negative DA numbers!! I should be already there but the weather won't co-operate here. Also the local track is very hard to hook up since they don't prep it. :(
Congratulations.
A4 and M6 Record
60' 1.59
1/8 7.56@89.8
1/4 11.909@113.1
backed up with a
60' 1.624 Spinning
1/8 7.57@90.27
1/4 11.897@113.6
GreenbeanZ28
11-15-2005, 10:10 AM
Congratulations.
Time to load up the car and driver for hours like we did with Shon's car!
Tekprodave
11-17-2005, 12:12 PM
I finally got some decent weather. 0 DA or so. I'm just a few hundredths off but I'm coming for ya Shon. LOL!!
11.928 @ 113.909
Shon Herron
11-17-2005, 01:37 PM
11.928 @ 113.909
GOOD JOB!!
That means I got to do some crap over the winter, wont be able to rest like a couple of others were able to do for 3 years.....
Shon Herron
11-17-2005, 03:37 PM
so who has teh fastest lt1 car with white leather, on 18 inch spinners and neons under it????
I am guessing you want to try for that one.....
Tekprodave
11-17-2005, 05:56 PM
GOOD JOB!!
Don't worry Bro. My failing posi and other issues may keep me out of the game for a while.
GreenbeanZ28
11-18-2005, 10:21 AM
Look at the MPH!
Shon Herron
11-18-2005, 01:32 PM
i was gonna go for fastest 6 speed f body but i decided to sell my car for a z06
Some decisions are worth the sacrafice, sure would like to just drive the new Z06s....
taner
11-18-2005, 04:43 PM
lol, nope
sellout :p
Tekprodave
11-18-2005, 05:57 PM
Look at the MPH!
I know. It surprized the hell out of me too. She pulled hard all the way to the stripe. One run a slipped a bit off the line and hit 114.375 MPH! I may get one more shot if the weather holds up.
meengreen 94z
11-24-2005, 09:10 AM
Sorry guys I've been busy.
Does anyone have a complete copy of the list they can email me? I didnt realize the new "quick" edit feature limited the size of the post and it unfortunately cut out most of the list.:cry:
amean94ta
11-24-2005, 10:28 AM
here is a old version dont know if it helps or not
1996 Formula WS6, 396ci LT1, AFR 220cc heads, 91.5mm Turbo, Madman suspension
¼: 8.352 at 168.45
383ci LT1, LT4 heads, Vortech YSi trim
¼: 8.928 @152.61
1/8 5.750 @123.96
60 foot: 1.341
¼: 9.04 at 155.33
¼: 9.06 at 148
60 ft.: 1.27
¼: 9.08 at 159.79
Dave Diluca
¼: 9.11 at 154.59
1/8: 5.87 at 120.88
60 ft.: 1.36
Dave Ducote/Brian Jeffries/Madman- held the fastest LT1 record, date unknown
Brady Mcnew
1996 Camaro Z28
1/8:5.91 at 112
60 ft.: 1.49
Jay Billingsley,
1993 Z28
Joe Overton
1994 Trans Am-First N/A LT1 in the 9's- Holder of the fastest Naturally Aspirated stock susp. LT1 4th gen- Holder of the fastest 60 ft. on stock type suspension(1.249 )
¼: 9.361 at 143.17
1/8: 5.93 at 115
60 ft.: 1.304
“Big Rick” Rick Intrau(OLD SETUP)
1996 Formula WS6, 396ci LT1 w/ nitrous
¼: 9.38 at 149
1/8: 5.92 at 119
John McMullin?? (couldnt find any more information on him)
1994 25th Anniversary T/A
1/4 mile: 9.4@150MPH???
Stefan D.
1993 Trans Am
1/4:9.41 at 141.12
Taner Bosnali
¼: 9.44 @ 146.18
60 foot: 1.355
Camaro Z28
¼: 9.52 at 142
60 ft.: 1.30
Ralph Olivarez/Madman,(car formerly owned by Dallas Castro)
1994 Camaro Z28
1/4: 9.56 @ 141mph
1994 Camaro Z28
1/4:9.57 @ 142.7
60 ft: 1.35
Jason Warren
1995 Camaro Z28
350ci LT1, Ported LT4 casting heads, w/ 300 shot of nitrous
¼: 9.58 at 140
60ft.:1.28
Ric "Tubby"
1997 T/A
1/4: 9.581 at 141.15
60 foot: 1.37
Sammy Vedros -N/A
396 LT1
1/4: 9.62 at 13X
60 ft:1.29
¼: 9.63 at 142
Jim Moran "INTMD8"
Steve Quinn
1995 Camaro Z28, 370ci LT1, Ported factory LT1 casting heads, Naturally Aspirated, w/ race wt @ 3052
¼: 9.713@138.16
1/8: 6.277 at 108.3
60ft: 1.271
Daren Wlodarczyk
1/4:9.763@138.49
60ft: 1.372
Jeff Stevens
¼: 9.82 at 145.03
1/8: 6.34 at 112.05
1/8:6.39 at 108.7
Tony Shepherd
93 Z28
396 LT1, hydraulic cam, AFR 190cc, 250 shot
9.85 @ 140.7 MPH
1/4: 9.85 at 135.5
1994 Camaro Z28
1/8: 6.43 at 112
1995 Camaro Z-28
1/8: 6.55 at 110.52
60 foot: 1.55
Dave Odehnal
1993 Camaro Z28
1/4:10.15 at 134mph-Naturally Aspirated
60 foot: 1.37
1994 Camaro Z28
1/4: 10.18 at 132- Naturally Aspirated
60 foot: 1.38
Matt "Nostang 96z"
1996 Camaro Z28
1/4: 10.27@133.24
1/8: 6.595@107
60 foot: 1.592
Jason Brisson
1995 Z28 1LE
1/4:10.40@130.7
Ed Wright
1996 T/A
383ci, LT4 heads & intake, 4L60E, 4000 Vigilante TC, stock pcm
1/4: 10.44 at 127.44 mph.
60foot: 1.33
JucinGTA
1997 Camaro Z28
1/4:10.44 @129
1/4: 10.46 @ 128-Naturally Aspirated
N20Dave- 6-speed
1/4: 10.47 at 131
1/8: 6.70 at 103
60 foot: 1.55
Joe Overton
¼: 9.361 at 143.17
1/8: 5.93 at 115
60 ft.: 1.304
Sammy Vedros
396 LT1 NA
1/4: 9.62 at 13X
60 ft:1.29
Steve Quinn
¼: 9.713@138.16
1/8: 6.277 at 108.3
60ft: 1.271
1/8:6.39 at 108.7
Vince McCauley
1/4: 9.93@135
Dave Odehnal
1993 Camaro Z28
1/4:10.15 at 134mph
60 ft: 1.37
1994 Camaro Z28
1/4: 10.18 at 132
60 ft: 1.38
Ed Wright
1996 T/A
60foot: 1.33
1/4: 10.46 @ 128
Clyde Moore
1/4: 10.66@128
1996 Camaro SS
10.744 @ 127.04
60ft.: 1.49
Dave Smith
10.76@131mph
Jordon Musser
1/4:10.80 at 130
1/8: 6.9 at 100
1/4: 10.8 at ???
Tim "95Bird"- 6speed
1/4: 10.81@124.8
60 ft:1.47
Stefan D
1993 Trans Am
1/4:10.82 at 128
Travis Linville
1994 Z28 Hardtop
1/4: 10.83 @ 127
Ken "Kamba93LT1"
1993 Z28
1/8: 6.950 @ 98.23
60 foot: 1.442
FASTEST 6-SPEED LT1
Taner Bosnali
¼: 9.44 @ 146.18
1/4: 10.744 @ 127.04 -Naturally Aspirated
FASTEST BOLTON LT1
SAR2K-Jan '03
11.94 @ 111.5
60 ft: 1.53 60'
3510 race weight
1996 Trans Am
1/4: 10.86 @120
60 ft: 1.38
Mike Alford "Mike Comp T/A #57"
1995 Comp T/A #57
auto, longtubes, elect. WP, 52mm TB, QA1 & Spohn suspension, 150 shot, 3800lb raceweight
1/4: 10.89 @ 128mph
1/8: 6.89 @ 100mph
60ft: 1.47
Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers,Crane 210/224, 1.6rr,Strange 12bolt,QT Pros, Vig3200.
1/4: 11.40 at 116.59
60 ft:1.483
Steven Quinn 10.5 at 130? (more info/needs to be confirmed)
Ported stock heads/hydraulic cam
1997 Camaro Z28
1/4: 9.85 at 135.5
meengreen 94z
11-24-2005, 12:09 PM
Thanks! that helps alot. I'll try to peice the list back together later today.
Shon Herron
11-24-2005, 12:35 PM
Well, put Tekprodave at the top of the list, he ran a 11.891@114.x last night, he is an auto car so I still got the fastest/quickest M6!!
Tekprodave
11-28-2005, 12:23 PM
Yeah put my time up there quick. It may only last 5 minutes. :lol:
Looks like I won't get another chance for a long time. It's been raining every day since thanksgiving and the evening drags are done until at least March depending on the weather.
Frank95z
12-01-2005, 12:49 AM
Tonight I ran a new best with my cam only Lt1. I am running the same combo that I have run for the last 5 years except I changed to a custom grind Joe O cam. My new record is 11.30 118.19 the da was -700ft and my race weight was near 3300#s. Whoever is keeping track of these results please change my time and cam type . Frank95z I will post a more detailed thread tommorrow.
Tekprodave
12-01-2005, 12:12 PM
Very nice!! Congratulations. :bow:
meengreen 94z
12-04-2005, 03:37 PM
Fixed it:)
Frank95z
12-11-2005, 11:44 AM
Meengreen I ran at NPR on Friday night. The weather was good(-800)but the track was cold. My 60fts were off .05 but I managed a 11.273 at 118.90. My race weight was 3325. Frank95z
Shon Herron
12-11-2005, 09:52 PM
NICE!!
Keep it up, give me a good target, HA!
Tekprodave
12-12-2005, 11:20 AM
NICE!!
LOL!! I was thinking of doing a cam only config next too. And then maybe cam+nitrous and see if I could hit a 9.xx:alert:
T/A lt1
12-13-2005, 09:16 AM
Meeangreen I noticed you dropped my times from the list. I should still be up there. 355" LT1, CC306/ported LT1 heads, 4k PI converter, 3.55 gears, 200HP n2o on dragradials . Later Clint
1.53 60'
6.50@106mph 1/8th
10.17@134mph 1/4.
meengreen 94z
12-17-2005, 11:19 PM
1.53 60'
6.50@106mph 1/8th
10.17@134mph 1/4.
Your still on the list:) Look under the power adder section.
95Bird
01-19-2006, 12:41 AM
Please update
10.48 @ 130.4 1.437 60' same mods as before.:D
Alittle over 3300 lbs.
taner
01-20-2006, 11:28 PM
Please update
:bow: congrats man, stephen said you would be heading to the track soon! awesome numbers!!!!
95Bird
01-21-2006, 01:03 AM
Thanks Taner, I know it won't be good for very long when you head back to the track...but I plan on breaking it myself here shortly..lol.
taner
01-21-2006, 09:08 AM
so is it 10.49 or 10.48 ....you need to make your mind up :p
it will still be a while before car is back up and runing, just a freshen, and Eric Bradby has my heads, apparently they weren't flowing what i was told last year!!! wtf! anyhow that and couple of other "slight" improvements :cool: nothing drastic though.:D
Jeff 96 SS
01-21-2006, 09:11 AM
You can add me to this list too. I have a time slip and video to prove this run.
Jeff Gilbert 60ft1.48 1/8 6.14@114.85 9.56@143.78
96 TransAm raceweight 3875# 396 D1 procharger 100 shot
I have been faster but can't find the slip the car trapped 146! I was having serious problems launching the car but I fixed that on the last day of the season cut a 1.39 tripping the beams with the back tires :) and aborting that run early. I have done some serious weight reduction on the car and found some more HP so I'm shooting for 8s this year I'll crush this number in a couple months.
Jeff
96 SS BLOWN
96 TA 396 D1
