86' 305, need advice
Yossarian14
09-30-2004, 12:19 AM
I have a 1986 Camaro with a 305 and carb and need some advice on what to first for some more power. I know I didnt give much info but some people tell me I should get a 350 in there or larger, some say the 305 will do, and others say I can they are the same blocks. What should I do?
Jaswir
09-30-2004, 12:44 AM
Depending on the money you want to spend i would go with a 350... but for some extra power get some headers, and a nice exhust system.
ShopRodder
09-30-2004, 01:04 AM
stick a larger carb on there, depending on what was on it before you will notice a increase of power, not sure what you would have to do to the chip afterwards for it to work, I awalys riped mine out on the first chance. But yea if you willing to spend the money a 350 is your best bet, the 305 ain't going to do enough for ya, or atleast not for me it didn't.
robvas
09-30-2004, 08:43 AM
I'd do mods that you can use on the 350 that you'll eventually put in there :)
Intake manifold, headers, suspension upgrades...
Sitting Bull
09-30-2004, 01:28 PM
A larger carb will do NOTHING for a 305. The QJet is plenty big enough.
Headers and a 3 inch exhaust will really make a difference.
Yossarian14
09-30-2004, 05:10 PM
It is not true that the 305 and 350 share the same block? Someone told me that the only difference is the length of the stroke and I could make it a 350 with the obvious changes. So do you guys beleive I should stick with the 305 or go to a 350 or bigger?
WS Sick
09-30-2004, 05:29 PM
The 305 has a 3.78 inch bore and a 3.48 inch stroke. You woul dhave to bore the block a whole bunch to make it the 4.00 inch bore of a 350(can't do too thin off cylinder walls.)
I would start by making sure your quadrajet is healthy, then add a nice alum intake and some exhaust mods. then save for a 350..lol
Really , if you can afford a 350 it will get you alot more than tinkering with the 305.
Yossarian14
09-30-2004, 05:44 PM
Alright to be truthful I am only 15 right now and do not know much but I understand what you are talking about. The only thing Im concerned about is buying parts for a 305 that wont work on a 350. Is there anything that I cant swap over when I get a 350 like heads, intake manifold,headers, etc. See I know enough about cars for my age but not that much hands on experience. The only thing I have to tinker with is a f-150 motor and a moped motor.
musclecar
09-30-2004, 06:13 PM
I would scrap the 305 and get a 350. For now though, try headers, exhaust, and maybe even a cam. (After all that, might as well just swap engines :D ) I have a friend that put a cam in his 305 and it runs ok, but it's no 350. As for the exhaust, I wouldn't go any larger than 2.5 inch. Even better would be 2.25 due to the fact that backpressure helps small block chevys make torque, something that a 305 does not do. All of your upgrade parts will be interchangeable with the 350. The heads would be the only hang up due to the smaller chambers of the 305. Hope this helps.
Yossarian14
09-30-2004, 07:23 PM
Ya this helps quite a bit, now just to convince my dad to let me purchase a 350, I need to buy heads for the block too though. I'll prob do exaust, manifold, carb, etc for now and then in a year or two after a job I'll put a 350 in or maybe a higher cube. I want some horsepower and nitrous is too iffy.
steve10358
09-30-2004, 10:02 PM
Sittingbull, can you please reduce your sig to 5 lines?
Sitting Bull
10-01-2004, 02:40 AM
How about if I use it sparingly?
I really do try to not include it. I wish there was an option in the control panel to turn it off by default. I just wanted to give the guy some ideas about what he can do with a 305.
WS Sick
10-01-2004, 10:27 AM
Everything that exteriorly bolts to a 305 will bolt to a 350 (inmost cases).
So intake waterpump, heads, exhaust all cam be moved over to the 350 when you get the shortblock built or bought. Remember though with a 305 if your getting heads the largest intake valve you can go with without modifications to the block is a 1.94. so if you put a nice set of heads on it make sure it has 1.94 intake valves and not 2.02s.
the 305 was built for torque, not high HP, it has a long stroke (same as 350) but a small bore (bad for breathing). I would put the exhaust system that you plan to finish with on, so make it for the 350, you will have some sluggishness down low maybe, but when the 350 gets in it will be done and youwon't have to redo it.
Dragula85Z28
10-01-2004, 02:00 PM
well i can honestly say i was very impressed with the results out of my 305 a few years back.
i had a performer cam, manifold, lifters, headers, 3 inch cat back, 700r4, 3:73 rear, holly 600 cfm. shift kit and i was able to run a 14.2 with it.
but now i have a 350 :D :D :D :D
But i still wonder if i had head work done and maybe a shot of juice what it might have ran then
Yossarian14
10-01-2004, 05:10 PM
Whats it like doing engine work on a 1986 Camaro? Is it a pain in a the butt the with that polution control junk? Can I swap any part in or out easily or do I have to worry about compatibility?
Pneumatic_Tire
10-02-2004, 07:53 PM
Well, first thing you can do is just get rid of the emissions componets IF you're state does not have inspection. I live in Columbiana county in Ohio, and that stuff went by-by. More room in the engine bay and frees up some horses. As far as compatibility issues, you shouldn't run into anything since just about anything accessory wise will match right up with a 350. This includes your distibutor, headers, cylinder heads (but 350 heads will not work on a 305, just for the sake of knowledge) accessory brakets, alternator (provided you dont do any insane electrical stuff) water pump, water neck, plug wires, fan, radiator. Just about everything. lol.
All in all, it's pretty easy to do work on 3rd gen Camaros. Nothing is really hard to get at, and you shouldn't have any compatibility problems.
Yossarian14
10-03-2004, 04:29 PM
If you take a 305 out and stick a 350 in a 1986 Camaro, how much work will it be? Will the 350 work with the motor mounts, transmission, etc?
Pneumatic_Tire
10-03-2004, 08:17 PM
Motor mounts are the same, same block size. You can't tell the difference just by looking at the blocks side by side. As far as the transmission bolt pattern, im about 98% sure they are the same too. Somebody else should be able to come in and confirm my other 2%.
fbodyfreak
10-03-2004, 08:37 PM
I am in the process of swapping an 88 305 tbi for a 350, I decided to go back with the tbi for isnpection purposes. You will get a lot more power from a 350, but at fifteen, I sugest you get some driving experience under your belt before you go for more power, you dont want to waste a good f-body by wrapping it around a tree or worse another car.
Nate86
10-03-2004, 10:04 PM
There's no doubt that a 350 would make much more power than a 305 with equivalent work done to each. However, there's nothing stopping you from making the most of what you have.
I'm going to assume you have the standard LG4 V8 which was rated at around 145-160 HP, depending on the year. If you have an L69 (same engine except with some minor changes and a "beefier" 190HP), then you have a lot of the work done for you already.
Start with the very basics. The stock air cleaner is a horrible choice for air induction. The air cleaner only has one snorkel, and the snorkel is tiny at that. Grab a dual snorkel air cleaner off of eBay for a 5.0L H.O. Camaro which has two large snorkels which draw in air from two places, rather than one. However, the dual snorkel air cleaners are becoming exceedingly rare and expensive. Alternatively, you could buy an open element air cleaner (which cost about $40 at AutoZone) but the drawback here is that it draws in hot, less dense air from the engine bay compared to the cool air of the dual snorkel. You could also fabricate a custom cold air intake for your car, but you would have to take measurements, buy all the parts, and fix everything up youself which could be costly and time consuming. The best bang-for-the-buck here would be a dual snorkel air cleaner if you can find one at a local boneyard.
Moving on, once you get more air flowing into the engine, you're going to need to work on getting more air out of it as well. The best way to go about this is to upgrade the entire exhaust, all at one time, "from the heads to the street," to quote RB. Plan on putting on headers, a y-pipe with a 3" outlet, a 3" in/out high flow catalytic converter, and a 3" in/out high flow muffler. If you plan on using this exhaust later on down the line, pick parts that are made of stainless steel. I would have the headers ceramic coated as well (reduces underhood temperatures; protects against rust), but you can decide whether or not to do that based on your budget. As far as what brand to buy, you're on your own there. There are too many different headers, cats and mufflers on the market for any one person to say "this is the best." You're basically going to have to do some research and use your best judgement and preference when picking out your parts.
The next step would be a cam upgrade. The peanut cam that the LG4s came with is by far one of the worst (if not THE worst) cams ever put into a GM engine. I'll be honest with you: I'm far from an expert on cams. The least I can recommend for you about this would be to go with a computer-compatible cam. This will keep the ECM from throwing a fit due to the change of camshaft. Ask around this site or thirdgen.org for camshaft recommendations.
The heads that come with the LG4 weren't nearly as bad as the cam, though. They can be self ported and polished to flow extremely well and there are numerous places you can go to find out how (one resource is already provided for you in Sitting Bull's signature). Your '86 will have the heads of the 416 casting and used 1.84" intake and 1.50" exhaust valves. If you decide to P&P these heads, install some 1.94" intake valves with it... as well as upgraded valve springs to match your cam and screw-in rocker studs. After all that, these heads will flow quite well. Alternatively, you could always buy World Castings S/R Torquer 305 heads and port them. The rest of the stuff is included.
Your engine should be a lot more powerful by now, but if you still want more out of it, take a look at the intake and ignition. As far as intakes go, I hear Weiand Action+ or the GMPP Quadrajet intake manifold are both good choices. Don't bother with the Edelbrock Performer intake though... it's not much, if at all, better than the stock intake. Looking at ignition, you'll want to pick up an aftermarket control module and coil. The stock ones are fine for a stock LG4, but are quite weak and failure prone when the engine is beefed up. MSD and Accel both good choices for these parts. Quality plug wires don't hurt either (8.8mm wires should work great). As far as spark plugs, just stick with the regular AC Delcos... platinum and multi-electrode plugs weren't designed based on our HEI style ignition and therefore offer no benefit.
Besides adding nitrous, that's pretty much as far as the average car enthusiast is going to go with the LG4. Any other modifications besides these can get tricky or expensive.
That said, there are still lots of things that you will need to do to take advantage of your engine's newfound power. You'll definately want a higher stall torque converter to take advantage of your new cam's powerband. A posi unit for your rear end is essential to have if you don't already have one, and lower gears (higher numerically) will improve your acceleration from a stop immensely... although it will lower gas milage and top speed slightly.
Your chassis is next up on the list (should actually be the first, but since you asked about "more power" I put it below). A hard tops' chassis should hold up relatively well even without mods, but T-Tops are prone to cracking at the sail panels from flex caused by the higher torque of the engine--to be fair, I've even heard of cracks being made with the engine completely stock. To combat this, you'll want subframe connectors at the very least. A steering brace and a strut tower brace would be even better, but not necessarily required. However, SFCs are a must.
Chances are the suspension in your car is probably garbage, with the exception of perhaps sway bars (if you have large ones). The rest of the suspension is weak and needs replacement. Plan on buying high performance struts/shocks, springs, lower control arms & relocation brackets, a panhard bar and a torque arm if you want to put any of that power to the ground. An aluminum driveshaft would free up some weight and remove high speed vibration as well.
Now that we've talked about what will make your engine more powerful, let's talk about what will NOT:
-An aftermarket carb. The quadrajet flows up to 600CFM when in stock form! That's more than enough for your 305... and it can be tuned to flow even more. Not to mention that if you do get a different carb, you will have to change the distributor as well.
-Plugging the EGR. Some people falsely believe that the EGR system hinders performance, when in actuality it could be helping it! The EGR is intended to reduce combustion chamber temperatures which has the side benefit of allowing the ECM to advance the timing further than it normally could.
-Removing emissions equipment.If you're going to be ripping out emissions stuff, make sure you know exactly what you're doing and why. The only two systems I can think of that can be taken out without any adverse effects are the A.I.R. injection system and the EFE system. Everything else pretty much serves a purpose... emissions related or not.
I commend you if you're still reading this far, because this has taken me more than an hour to type out. I'm almost done though. :D ;)
Finally, there's some stuff I should have mentioned before any of this but I forgot to put it in the beginning. The very FIRST thing you should do to your car is give it a complete tuneup. I can't emphasize that enough. When you do a full tuneup on your engine, you pretty much return it to the way it was when it rolled off the showroom floor. If you take a beater with old plugs, wires, oil, coolant and the like and try to make it faster, you'll be left scratching your head as to why your car isn't making more power after spending lots of money and time on parts and labor. Do a tuneup to avoid all that.
As far as oil goes, I won't tell you what oil to buy or how to change your oil, but I will tell you what I do to my own car based on my experience and research. I only use Mobil 1 synthetic 10W-30 in my car. Without going into detail, synthetic oil is in every way better than conventional oil. It breaks down much slower than "dino" oil, it has better heat resistance and it works as a cleaning agent to remove old sludge and carbon that has built up from the breakdown of dino oil in the engine. I use Mobil 1 for the convience and price, but there are plenty of other synthetics out there as well. I try to use the AC Delco PF35L oil filter with my car, but if it's out of stock I stick with the PF1218. Both of them flow well and filter plenty of dirt.
Tuning the carb is something a tad different than everything else I've discussed. It doesn't really fit into the "make-more-power parts" discussion mentioned ealier but it doesn't belong in a general tuneup and maintenence discussion all that well either. Fortunately, it's not too hard to do... even for a novice. Instead of typing the whole procedure out, I'll just give you the link to a tech article on how to do it:
http://www.thirdgen.org/newdesign/tech/quadrajet.shtml
After ALLLLLL of this, you should have one hell of a car which will be plenty capable of low- to mid-14s in the quarter without any power adders. Add a 75-100 shot and you've got a 13 second car (stock LS1 territory).
Anyway, good luck and have fun with your car... whatever you decide to do with it.
