'68LT1camaro
09-29-2004, 08:21 PM
Does anyone know if a Gen 7 DFI set up is compatible with a Delteq set up? Does anyone run this set up?
Thanks. :D
_____________________________________________Raymo nd
sseeya
09-29-2004, 10:07 PM
It should be, as long as you have the LT1 specific DFI which is designed to use the optical signal from the Optispark.
Sean94Z
09-30-2004, 09:28 AM
I don't know for sure, but, if you are giong to spend money on a delteq, why not just witch to a dual sync distributor and ditch the opti all together?
'68LT1camaro
09-30-2004, 02:20 PM
I will be switching to an Accel Dual Sync distributor as soon as money allows.
This question is just out of curiosity.
texanmutt
09-30-2004, 07:01 PM
They delteq will not effect the operation of DFI in any way. This because the delteq does not alter the signals that the opti generates.
