Finchinater
09-29-2004, 03:00 PM
Went to the site and only saw the earliest programs for 94's. I realize that it's speed density, but shouldn't there be apps for that also. Please help. My woman has a laptop and would like to get some logs and programming done.
Finch
madwolf
09-29-2004, 06:49 PM
www.tunercat.com
You will also need a eeprom programmer and a piggyback adapter is recommended.
www.moates.net for the other two.
Also get the SST flash chip from him while you're at it. This will save you some money and time by not having to burn and erase a new chip each time plus no need for UV eraser.
Highlander
09-29-2004, 08:45 PM
Hey madwolf... is it totally impossible to have 2 flash chips on the $EE PCM? so one can switch from different programs?
Highlander
09-29-2004, 08:53 PM
I was thinking on getting the usb to aldo converter along with both cables... it would be really neat...
Alvin@pcmforless.com
10-01-2004, 11:11 PM
Moates sells a new USB -> ALDL cable that can flash the 94-95;s (as you know some cheaper cables cannot)
They've worked on most labtops i've tried them on.
www.moates.net
