Where to mount fogger with SLP airbox and bellows?
Slayn
09-29-2004, 10:36 AM
I'm asking because the only spots I can put it with the ram-air are right infront of the TB on the sides, WP takes up the bottom and I don't think there is enough room on the top of the bellow and I was wondering if the fogger is real close to the TB mounted on one side would it still mix somewhat evenly will all cylinders? Thx
mrr23
09-29-2004, 07:39 PM
that's where i have mine on both cars. 99 formy just went 12.236 @ 118.15. the 00 formy has been 11.97 @ 118.
http://www.stealthram.com/99formulanitrous.html
http://www.stealthram.com/2000pontiacformula.html
Sunsceamer
09-29-2004, 08:31 PM
Is that the cold fusion set up? If so what gain from motor are you getting and the shot size?
mrr23
09-29-2004, 08:35 PM
the black one is a compucar set up. it's set for 200hp. goes from 13.60 @ 101 to 11.97 @ 118. the white is a nytrex set up. it's set for 150. went from 13.25 to 12.236 @ 118.15 the night a first tested it. couldn't hit it until 2500 rpm. and had some spin most of the time. fixing to go to a better track and put it in the mid 11s. going to up the shot to 175.
