How to keep car (A4) in 3rd on the dyno???
BigRed1
09-28-2004, 03:50 PM
I'm just looking to find a way to keep the transmission from kicking down on the dyno for a true reading. I have LT-1_Edit if it can be tuned in that. I've only tuned OD (haven't messed with the D settings yet). Thanks in advance and take care.
94ZRiCeKiLr
09-28-2004, 07:57 PM
floor your car in second and see what the max MPH is before it shifts...then just make sure you take the car up a little past that speed before you drop the hammer on the dyno.
you can also use a certain scan tool (sometimes referred to as a lock-out box) to manually lock the tranny in 3rd.
most techs that i've seen just make sure to keep the speed above the 2-3 shift point before making a pull.
BigRed1
09-29-2004, 10:23 AM
I tried lowering the 2-3 kickdown point with no luck. Tried running the car in D versus OD (shot in the dark). I don't know where to get a "lock-out" box. Any other ideas? Thanks.
94ZRiCeKiLr
09-30-2004, 03:02 AM
hmmm....can't say as i can explain that one. when they dyno my car, the tech usually just takes it up to around 85 mph (like 2800 rpm in my car) with the selector in D and floors it. it holds 3rd.
1996SS
09-30-2004, 09:33 AM
pull the fuse out trans will be in 3rd
BigRed1
09-30-2004, 09:58 AM
Fuse?!?!? Please explain.
