Too much play in the steering wheel
75 outlaw LT
09-26-2004, 06:15 PM
On my '75 LT there is about 1-1 1/2 inches of play on the steering wheel. My father suggested a new steering box. Is there anyhting a little easier/cheaper that I could do to fix this? Or is that the ultimate solution?
angel71rs
09-26-2004, 09:11 PM
Check for worn components while someone works the steering wheel. Idler arm, rag coupling, etc.
You can also try adjusting the steering box, but you'd be best off taking it to a suspension shop to do it:
http://www.partsmikeparts.com/saginaw_steering_box_adjustment.htm
Todd80Z28
09-28-2004, 08:33 AM
How's the front end alignment? Is the toe-in correct?
75 outlaw LT
09-29-2004, 05:27 AM
Yep, just took it to Goodyear and got an alignment done, full suspension replaced with KYB shocks, and still no help. My brother-in-law (previous owner) tried to fix it by tightening the nut on the steering box and it still didnt help. My guess is the box itself is shot. So I'm gonna try and look for one at a junk yard.
Todd80Z28
09-29-2004, 08:10 AM
Take a look at the rag joint on the steering shaft going into the box, first.
69camroking
10-02-2004, 06:05 PM
My camaro was pretty loose in the steering dept. but replacing the ball joints and pittman/idler arm cleared it right up for me.
JamesTKirk41
10-05-2004, 04:40 PM
Check out this thread from NastyZ228.com's big board.
http://www.nastyz28.com/ubb/Forum10/HTML/006036.html
Instructions on steering box adjustment.
