Smokn '94 Z
09-26-2004, 12:28 PM
Hey. I am just wondering if I were to build my LT1 for N2O, what would be a reasonable compression ratio to have it set up for running 150 shots?
Thanks.. :bow:
Thanks.. :bow:
What Compression Ratio For N2O?Smokn '94 Z 09-26-2004, 12:28 PM Hey. I am just wondering if I were to build my LT1 for N2O, what would be a reasonable compression ratio to have it set up for running 150 shots? Thanks.. :bow: RacinLT1 09-26-2004, 05:29 PM i wouldnt build a dedicated nitrous engine for only a 150 hit,build it for good n/a performance then spray it. 11:1 is fine and still allows pump gas with no issues,just build it with good forged parts. I ran my stock LT1 with a 150-175 shot and had no problems,and it was a safe tune,i was in the process of leaning it out on the nitrous when my trans imploded. rskrause 09-27-2004, 07:28 AM I agree with the previous post. However, you probably should select a cam with nitrous in mind - relatively long exhaust duration with a fairly narrow LSA. Basically, a good NA cam with some extra exhaust duration. Chose the static CR to go with the cam, aiming for a dynamic CR of ~8:1. Rich | ||
