dabez1
09-25-2004, 10:18 PM
What pressure are your tires at for everyday driving. Its my daily driver but i race just about everyday and was wondering if i should drop the psi since they are at 44psi.
Tire pressuredabez1 09-25-2004, 10:18 PM What pressure are your tires at for everyday driving. Its my daily driver but i race just about everyday and was wondering if i should drop the psi since they are at 44psi. Kataklysm 09-25-2004, 11:26 PM Yes drop that pressure. You have it set to the max on the tires. What size tires are they? I have 275/40/17 set at 35 psi for daily driving (recommended on door sticker) Go by the setting on the door. Hawk#1412 09-26-2004, 09:31 AM Keep mine between 32-34psi, getting even wear all the way around. Fuels94TA 09-26-2004, 10:04 AM Keep mine between 32-34psi, getting even wear all the way around. ditto, also give room for when the tire heats up the pressure will raise about 2 psi. 44 psi is just to high. Pandamonkey 09-26-2004, 11:29 AM Yup - right around 32 is where I keep mine.:) shoebox 09-26-2004, 11:41 AM :eek: 44?? :eek: Ever read the tire pressure sticker that is on the door? dabez1 09-26-2004, 06:32 PM Just got new tires, cooper cobras GTH, They were set at the PSi, Need4Camaro 09-26-2004, 07:15 PM Dumb question for me, but besides jabbing the living h3ll out of your tire with a knife or pinning it to death with nails, how do you take preasure out of your tire? BlueEyedDevil14 09-26-2004, 07:24 PM LMAO, umm...maybe push down the pin valve? MysticTeal 95 V6 09-26-2004, 07:28 PM I run 36 psi in all 4 :) 1984camaroz28 09-26-2004, 07:47 PM i run 10 psi in my ET streets..... darthrug 09-26-2004, 07:48 PM Dumb question for me, but besides jabbing the living h3ll out of your tire with a knife or pinning it to death with nails, how do you take preasure out of your tire? i'm speechless. wheres your helmet lol. rncotton 09-26-2004, 11:06 PM 36 PSI all around for me for driving on the street. When I go to the track, I bump the fronts up to 40 and drop the rears to 24. 97FormulaWS-6 09-27-2004, 07:11 AM I run 32-33 psi cold on the fronts (555 Extremes, 275/40) and 15-18 psi cold on the rears (555 DRs 275/40). The fronts wear perfectly, the rears ALWAYS wear down the center first... | ||
