I want to supercharge my TPI
keythyscamaro
09-25-2004, 02:47 AM
I currently have a 94 camaro v6 and i basically got a 86 vette TPI and tranny for free. I was planning on doing the swap but i wanted to get a supercharger just to make sure i have enough power because i know TPI have a lot of torque but not so much horse. Any ideas where I can get a supercharger for this TPI it is a 5.7 liter.
SSnthe10s
09-25-2004, 03:02 AM
i think vortec makes one.
97WS6SCharged
09-25-2004, 03:06 AM
Both ATI and Vortech offer kits for the L98 motors. Tbyrne Motorsports usually has pretty good deals on their kits. :)
aklim
09-25-2004, 12:26 PM
Check the compression specs. If the motor is at 10.3:1, you might not want to supercharge it or you might get detonation which backs off your timing.
97WS6SCharged
09-25-2004, 01:03 PM
In a FI motor, detonation is more likely to break your pistons before the computer pulls enough timing to be effective. Also, aren't L98s supposed to be 9.3:1?
aklim
09-25-2004, 01:27 PM
That is where I am confused. Chilton says that they are 10.25 for 90-91 and before that 9.0 which would be lower than a F-body at 9.3. In any case, I would like to see a motor at say 8.5 before I supercharge it so I could run higher boost.
keythyscamaro
09-25-2004, 02:47 PM
I am wondering how much mpg would i get if i got a supercharger because right now with the 5.7 TPI i get 16mpg so me and my friend were arguing and he said i would get like 9 mpg?
97WS6SCharged
09-25-2004, 09:33 PM
My gas mileage wasn't affected very much. Maybe 1-2 mpg total, but then again it's hard to resist getting on it. It's nice to hear the whistle and feel the kick in the pants. Almost forgot, you will most likely need larger injectors because the stock 22 pounders aren't going to cut it. :)
My heads and cam affected the gas mileage more than the blower did.
Aklim, I've always read that the F bodies were around 9.3:1 compression with the 64cc iron heads and the Vettes were around 9.5:1 with the 58cc aluminum heads. Also, a true 9:1 compression is good for 10+ psi with an intercooler or a methanol kit on the street. I wouldn't hesitate to run a well maintained L98 at 10 pounds. If I were to swap in a set of forged pistons then more boost would definately be on the menu. FWIW, one of the 383s I'm building is for my 97 TA, it's about 9:1 compression with 58cc LT1 heads and I intend to run around 15 PSI on the street with a PT76GTS or PT88 turbo. The other is for my truck and at 8.5:1 it should see about 14 PSI on the street from two TO4B turbos. Turbos are more fun. :D
aklim
09-26-2004, 02:26 AM
According to my GM Serivce Manual, it is 11:1 compression.
Yes, you can run 9:1 with 10 psi but you need an aftercooler or something to cool the air charge. The thing I did not like about turbos is that you need some sort of intercooler which adds to the complexity of the system. As if we had that much space in our already cramped quarters. Of course, if we were to go that route, I would not hesitate to put the supercharger int eh car. I always thought it was a waste to run 5 psi boost becayse you pay the same or close to the same as a blower making 15 psi.
I would agree that properly set up, turbos are great because there is less parasitic power drain. However, the routing is going to be a nightmare in that small engine bay. Also, turbos love a large exhaust pipe so again, clearence is an issue
keythyscamaro
09-26-2004, 08:01 PM
My cousin said i should get a paxton supercharger for my TPI he said its way better then the vortech?
Dyosis
09-27-2004, 11:07 AM
I am not trying to knock Paxton, but there must be a reason most guys run Vortech's and ProChargers instead of paxton.
aklim
09-27-2004, 04:33 PM
I would choose Vortech over Paxton because Vortech will use the engine oil. With Paxton, you have to drain it every now and then and use Paxtatrac fulid which gets to be kind of a pain.
airtime
09-28-2004, 08:59 PM
procharger (ati) has a chart on there site for tpi cars. basically, if you go over 6psi on any system from any manufacture, you will need an intercooler. some people will disagree but if you run more than that you will have to piss away a but load of fuel to keep away detonation or pull the timing, both ways will kill power.
JAY'S 91Z
09-29-2004, 05:36 PM
I'm running an intercooled procharger p600b on my tpi. I make a bunch of hp and a boat load of torque (see sig) for a basically stock motor (tpi's are torquey anyway). Just make sure to check a/f on the dyno - no more than 12.5:1 and it should be good. I get no detonation, but should it occur, just back off on the btm. Also, my stock comp ratio is 9.3:1 :cool:
WS Sick
09-30-2004, 09:56 AM
All the later 350 TPIs I took apart had 58cc chambers and a nice 16-18cc dish in the piston. The math adds up to 9.5 or so on a 350 so I'd say the 9.3 would be what it was like said.
FruityOne
10-01-2004, 02:18 AM
I've torn apart two L98's, both happen to be from a 89 350TPI had flat tops with 4v reliefs in them. So its not always true.
The iron headed L98 has 64cc chambers, and the aluminum headed (read 86+ Vette) had 58cc chambers.
WS Sick
10-01-2004, 10:29 AM
Thats the thing about GM, you can never say never. I allways wonder if they just use what they have setting on their shelves at the end of a run instead of keeping things completely constant....lol
aklim
10-01-2004, 01:57 PM
Arao makes those 4 V heads
FruityOne
10-01-2004, 03:56 PM
Yeah, but I only have the 4v reliefs, my heads are just standard 2v sbc heads from a L98.
I've seen the claims for those 4V heads and they are impressive. I don't know if its just tire smoke, or actual truthful data.
