Forged rotating assemblies noisier?
Old Sep 24, 2004 | 11:51 PM
JimMueller's Avatar
How much noisier should a stock aluminum LS1 block be than the same one with forged rods & pistons? I bought this used last Easter. It's been reliable so far, but I certainly didn't expect this much noise. Now I'm trying to isolate a noise and I wish it were quieter, as it sounds like a diesel.
Are the iron blocks much quieter?
Old Sep 25, 2004 | 12:27 AM
Mindgame's Avatar
Re: Forged rotating assemblies noisier?
Does it do this (dieseling) at all engine speeds? When cold and/or hot?
The rod and crank materials don't mean much one way or the other. Some of the new forged pistons can be run at close piston-to-wall clearances without trouble. I'm wondering where your piston-to-wall clearances are. Any build sheet for this engine?
-Mindgame
Old Sep 25, 2004 | 08:38 AM
JimMueller's Avatar
I wasn't given a build sheet nor did I know to ask for one. I had a couple of experienced LS1 engine builders listen to it and it didn't seem out of the ordinary to them. One said his engine sounded like that too even though it was built to spec.
The dieseling noise is most pronounced at idle speeds.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
