mustangmuncher
09-24-2004, 01:11 PM
Its a 1996 Camaro Z28 A4 with 3.23 gears. It is bone stock, no free mods or nething. Second time at the track. My previous best was a 14.297, and I ran a 14.124 Wednesday at Thompson. A Master Tech at Ford says I must have slicks and a cam and ported heads to be running that... :rolleyes: screw him, hes upset that my car is faster than his fox body and his 99 GT vert auto. My 60 ft was a 2.234 and I had some major wheel hop, and a good amount of spinning. If I could get sticky tires I think I ould get a 13.9 :) . We will see. Future plans for the car are stock heads with a GM 847 cam. That will be in about a year though. Alright, thought I would share. Thanks.
-Eric
mrsneakyz28
09-24-2004, 01:20 PM
slicks a cam and ported heads would be more like 12.1 wtf??!
Fuels94TA
09-24-2004, 08:26 PM
I could see a 13.9 down the road for you on some BFG slicks. As for the wheel hop either get some better LCA, or switch the bushing out with some ILE type.
MdFormula350
09-25-2004, 01:54 PM
my car ran about 14.5's stock.
not bad at all.
HeavyChevySS
09-26-2004, 06:17 PM
13.9 is definately a possiblity ! You can do it.
When you do the new cam; do yourself a HUGE favor and invest some cash into your heads. Get them cleaned, 3 or 5 angle job and some porting done by someone who knows the LT-1 heads. These worked heads matched with a nice cam will yield more power than just a new cam. You'll be thankful you did it at the same time with the cam swap.
I know of 2 guys running cars with worked LT-1 heads and nice cams and they're in the low 12s. Right along side the guys who have aftermarket heads. :eek:
Heavy
Z-RATED94
09-27-2004, 03:34 AM
Do your self a favor and just do a cam first. A freind of mine went low 12's with just a Hot Cam and all the bolt ons. If your not happy,then do the heads.
BiGGinZ
09-27-2004, 01:15 PM
Those are good times with a stock a4. Now time for mods. Here is a link to the T.B. Bypass and it doesn't cost anything. Maybe $5 for a clamp and some caps.
http://shbox.com/1/tb_bypass.jpg
