milky
09-23-2004, 07:36 AM
Hey, nice place you folks got here, I could get used to this. :)
I managed (Through skill and dedication!) to run my beater '77 truck low on oil enough to melt a bearing or two in the old beast's 4-barrel 350. (Lost the oil filter. :o Yes, I am the weener, and still Champeeen! Gold star for Milky!!!)
By scrounging about, I have acquired a stock '82 2-barrel 305 that's got the intake manifold and heads off and loose for a great price: Free!
Unfortunately, the pushrods kidnapped 1 cylinder's worth of valves and springs, and lit out for parts unknown, leaving me with a bit of a dilemma, as I weant to get this motoer running for as cheap as possible.
Since there's nothing wrong with the 350's top end, could I just peel it off and drop it right onto the already peeled 305 without issues of valve clearance, pushrod length, rocker set-up, etc? Or are there any hidden but rude surprises I need to address? I'm kinda noob-ish at this small-block stuff, and this is supposed to be your basic switch-it-for-a-cheap-junkyard-motor type deal.
Except that some-one dissassembled the 305. I don't know why, as it seems nice and tight and shows little wear.
Eh, I don't care so long as it doesnt have rod-knock. All it's gotta do is fire-up and run.
So, you know any tidbits I wish I knew?
Thanks.
Milky
Thanks.
Milky
