Just curious a few guys told me i should look at getting this cam on atleast a 112lsa due to the fact that im gonna spray on it. But if they dont allow me to change the lsa for the GP thats going on i would still get this cam most likely.
And if i did that i was wondering what kind if any issues i would run into.
Thanks!
Ford
Z-Scrilla
09-24-2004, 02:46 AM
My cam is on a 110 LSA and I cant wait to spray on it. Ive heard the rumors about the dangers on spraying a cam with less than a 112 LSA, but I have seen many scenarios that prove them wrong. My N2O will be on soon, I let you know of the results. :cool:
Yeah, ill happily let you be the test mule ;) :D
rpm4lalo
09-25-2004, 02:40 PM
Ford,
You have nothing to worry about. That cam will make great power and work fine with nitrous. The LSA will actually help protect your stock bottom end for now since some of the cylinder pressure will bleed out. Of course you would probably get better numbers with a slightly tighter lsa but you are in no danger. Until you get to about a 200rwhp shot or more, I wouldn''t worry to much about the 111lsa for your setup.
