97s10ondubs 09-19-2004, 06:44 PM I got a couple salad shooters to throw some DR's on for the track, now I still have the stock gears which are supposed to take more abuse correct? My question is which tires should I go with, I'm not gonna do a burn out with them, I'm not gonna try and do 3k+ dumps, I have a spec stage 3 and dont wanna blow the rear, mainly I just want them for after I get off the line so I dont spin when I do punch it. The tires I have now break loose any time I punch it in first. Thanks for the patience and responses.
amean94ta 09-20-2004, 01:19 AM if your gonna choose between those two bfg the nitto's suck 1st choice should be et streets
Mickey Thompson makes an ET Street Drag Radial.
amean94ta 09-20-2004, 08:55 AM thats what i said lol
I thought that is what you said, but I specified "radials"...
1996LT1NY 09-20-2004, 12:42 PM M/T has a new E.T. Street radial for you. It's definately the best of the drag radials.... As far as track use goes dont bother with the Nitto's. BFG's are good, the M/T's are better
:thumb:
97s10ondubs 09-20-2004, 01:01 PM Ok, well i dont need the best hooking, but better than street tires, what about price? How much are the M/T's compared to everything else? And would it be bad to drive on them to the track? It's like 65 miles from my house. Also wont the better traction hurt my rear even more? Will the 3.42's give me a better chance of keeping the rear longer?
1996LT1NY 09-20-2004, 01:16 PM The M/T's are about $15 per tire more... but they do last longer than BFG's. As far as driving on the street with them... if it's raining or wet you'll need to be extra careful with any drag radial, but otherwise you should be fine. If you've been running with the 20's on there any tire on the salad shooters will probably help you out quite a bit.
You said youre not doing 3K dumps & no burnouts, i.e. not really abusing your stuff, so personally I wouldn't expect any problems unless the rear is already damaged for some reason
95zzz28 09-20-2004, 02:29 PM well, i wouldn't get a slick if i were u. if u want to keep that rear-end intact since u have a six speed i would stick with the street tires of buy the bfg's.
i am running the nitto's right now, but i drive alot. i need something that will hook decent and last, so thats why i chose the nitto's.
97s10ondubs 09-20-2004, 04:35 PM If you've been running with the 20's on there any tire on the salad shooters will probably help you out quite a bit.
LMAO I would NEVER put 20's on this car, that was my truck I had before 97 S10 with 20's, I sold it to buy this car. Anyways, I'm leaning more towards the BFG's, just in case I decide to go to the local races, plus I've seen ET streets, their slicks with like 3 lines going down the middle. Those just look like they would eat my rear alive, but you say they last longer? Next question, where do you guys get your tires the cheapest?
Spinner 09-20-2004, 06:21 PM I paid $312 to the door for my ET Street radials (255/50/16). They're soofffffffftttttt and real nice looking. Couldnt pass up the price. http://www.stang.cc/tmcaalbums/Spinner/mickeys.jpg
1996LT1NY 09-21-2004, 11:04 AM LMAO I would NEVER put 20's on this car,.....
OK no 20's... thats a good start for sure :D
Not those ET Street's... forget about those for a minute... check out the link below... much more on par with the BFG's than what youre thinking of :thumb:
http://www.jegs.com/cgi-bin/ncommerce3/ExecMacro/product/prod_image.d2w/report?prrfnbr=202489
1995CamaroZ28 09-21-2004, 03:05 PM How long do the Mickey Thompson ET Street Radial Drag Tires last?
and do they hook up better than the BFG's and the NITTOS
That question can best be answered by how you drive. Long burnouts, lots of street use will quickly decrease the lifespan. Used as a track only tire with reasonable burnouts my regular ET Streets will last a whole season, 16 points races, a couple of specialty events, and the bracket finals. Et Street radials have the same compound. I bet I could get the same wear out of them. Bear in mind I also run two classes and usually go rounds at each event so:
4 time trials x 16 =64
Probably six rounds at each event: 6 x 16 = 96
Specialty events= 30 rounds
So I figure about 190 passes.
1995CamaroZ28 09-21-2004, 03:31 PM so, do these last shorter than the nittos.. because i'm looking to not drive them everyday, but still use them on the street sometimes..;)
what do u recommend for the best traction.
3.73's and 2800 stall...
Nittos, BFG, or the new Mickey Thompson ET Street Radial Drag Tires? :D
Antz97ZNJ 09-21-2004, 05:33 PM BFG for the track, the way these fbody rears are, only thing you could do is say a few prayers before heading down the track
Nitto's have the best street life, Mickeys hook best at the track, and the BFG's hook better than the Nittos and will probably outlast the Mickeys on the street. You choose.
What hurts the rear the most is a hard launch, especially if there is no preload on the driveline. I would break the stock rear with 3.73's, Auburn Pro diff, and TA cover every 400 passes. I rebuilt it twice then bought a 12 bolt. I broke it on drag radials and I broke it with both a six speed and an automatic.
hozb817 09-22-2004, 03:05 PM Does Mickey Thompson make a 315 drag radial? How much do they normally cost for a pair?
