SnakeKilla
09-19-2004, 05:34 PM
Just bought a set of BMR LCAs poly/rubber and I was wondering which end goes to the front. They are the non-adjs.
Installing LCASnakeKilla 09-19-2004, 05:34 PM Just bought a set of BMR LCAs poly/rubber and I was wondering which end goes to the front. They are the non-adjs. NoFear95 09-19-2004, 05:47 PM Doesnt matter. I like to read the lettering from the outside. simple 09-19-2004, 05:48 PM if you bought poly/rubber, the rubber bushing goes to the chassis and the poly goes to the rearend, zerks facing the ground the point of that is to have less road noise and vibrations on the chassis end with the rubber bushing but still retaining some of the stiffness with the poly bushing at the rear Z-RATED94 09-19-2004, 05:56 PM Rubber bushing to the chassis, as simple stated. And yes, it does make a difference. NoFear95 09-19-2004, 08:12 PM Sorry, didnt know they were different on each end. Strange. SnakeKilla 09-20-2004, 09:27 AM Thanks for all your replies I will go ahead and install them right away!!! LetMeBurnU 09-21-2004, 02:16 AM Just bought a set of BMR LCAs poly/rubber and I was wondering which end goes to the front. They are the non-adjs. Im thinking of getting me a set of BMR lca's and im going with the tubular ones. BTW there's two kinds..........poly/rubber and poly bushing what is the difference between the two? they're both tubulars. And how much do they usually run for? i see them for 109.00. Mtrhds94Z 09-21-2004, 07:28 AM I paid 98.95 for the LCA's anbd 80.95 for a panhard rod[BMR's] from Thunderracing on one of their sales[that's 10% off]8/13/04.. Shipping was less than 13.00 and I had a few other small items in there too.. Watch the sponsors for sales, you can beat 109.00, that's for sure.. I think I saw 15% off recently also: See: http://web.camaross.com/forums/showthread.php?t=301973 Looked on their site.. don't see LCA's or PHR tho.. Eddie95Z28 09-21-2004, 12:22 PM Im thinking of getting me a set of BMR lca's and im going with the tubular ones. BTW there's two kinds..........poly/rubber and poly bushing what is the difference between the two? they're both tubulars. And how much do they usually run for? i see them for 109.00. The difference is that the poly/rubber has a poly urethane bushing on one end and a rubber one on the other. The poly/poly has poly urethane on both ends which is stiffer but transmits more road nois and vibrations. | ||
