Doing LS1 Brakes, anything else i need to do?
Z95m6
09-19-2004, 12:57 PM
My car is in need of an alignment so what better time to do a set of LS1 brakes. I bought a complete set lines, spindles, rotors and calipers. I'm planning on putting them on next weekend is there anything else i should do while i have everyhing apart. Thanks.
9T7 Trans Am
09-20-2004, 10:05 AM
While you are going through the trouble, you might as well throw in a set of good pads. I used the Hawk HPS pads, and they really grip well. Best $ spent on my 97' so far. I have a lot of pics in my Sig below.
rlax31
09-20-2004, 03:00 PM
I've decided to go with Earl's lines too. I'll be doing mine this weekend I think. Should be fun.....I hope
According to my Haynes manual, it looks like bleeding the brakes is going to take the longest. They have like a million steps defined in there.
Z95m6
09-20-2004, 03:07 PM
It doesn't seem like it should take long at all. Just remove the rim, unhook the brake line, ABS wiring and the undo the 3 ball joints. Then slap the new one back in. Seems rather quick and easy.
rlax31
09-20-2004, 03:11 PM
...then bleed, right rear, left rear, right front, left front. is it as lengthy as the haynes manual suggests?
