Valve Springs
Jason Dove
09-19-2004, 12:32 PM
Anyone local have a set of valve springs... I think it's stock diameter, and should be able to support .550 or better lift. I snapped one, so they're all coming out.
Tw!tchb!tch
09-19-2004, 03:49 PM
Was it a double ? Any other damage ?
bunker
09-19-2004, 05:35 PM
If you descide to buy Comp valve springs, I have a set of 740-16 steel retainers that have about 1k miles on them, I'm going to be taking them out for some titanium ones that are on order.
Matt
LT1Z28
09-19-2004, 05:51 PM
As far as damage goes at the moment it seems that the damage was solely to the spring going to just pop a new one check the guides out give her a compression test and let her rip.
Jason Dove
09-24-2004, 11:55 AM
Hey Matt, to run the Comp springs do you need to do anything else? Other than new retainers/locks, do I need Shims or anything?
bunker
09-25-2004, 11:09 AM
You need 7481-16 locators, 740-16 retainers, 987-16 are the springs. Fergot the PT# for the locks, you can find out.
Springs rate is 441lbs so they are pretty bad a$$
