1997 Camaro Z28 Rear Brakes Noise.ABS problems too
crazypurgatory
09-16-2004, 10:37 AM
I'm getting some squeaking from the rear brakes only when I make a
turn.
And the rotors are getting small scratches in them toward the outside end of them.
I Think I need those clips that look like an H?
The dealer says that I have to buy his pads for over 100 bucks.
Any body know where I can get them?
I called up Bear thinking that they made the PBR clapers but they dont.
Who makes PBR clapers?
Also my ABS is not working used to go in and off now off all the time.
When I was working at a tire place that I won't say the name because they suck. I had one of the mech put it on a scanner and he said that every code for the ABS was set. What do you think? I think it's a short in the rear or a bad conector? I'm also haveing problems off and on with the gauges too the speedometer acts like a tachometer my voltage meter goes down to 8.v and my AC starts getting warm. Turn the car off for a sec or too and it stops. :eek: :confused: :confused:
Thanks for any help :bow:
Chris G.
crazypurgatory
09-16-2004, 11:22 PM
Any body got any ideas?
I know now that's it's in the ABS because when everything went crazy today with my gauges the ABS light whent out.
And when the ABS light came on the gauges stated to work fine.
Chris G.
crazypurgatory
09-18-2004, 12:15 AM
TTT :cry: :cry: :confused: :confused:
