98+ steering knuckle question
M93Z
09-15-2004, 10:32 PM
I just finished installing a pair of used 98+ knuckles as part of a brake upgrade and I noticed the passenger side knuckle is about 3/4" closer to the spring than the drivers side. [Of course I didn't think to look at my old ones before I removed them.] Does this sound like one or both are bent or is there a difference between sides? The car is still up on stands and I'm going to hold off finishing it until I find an answer.
Thanks.
Jabberwocky
09-15-2004, 10:56 PM
Might be bent, the sure fire way to tell is to get an alignment, heck it might be bent in a beneficial way, you never know.
M93Z
09-18-2004, 09:16 PM
Installed the wheels and set it on the ground, the right wheel is leaning in at the top. Should there be this much difference from the original knuckle?
